Digital-Analogic conversion help
  • Thread starter Thread starter esmeco
The discussion centers on finding the expression for current I2 in a digital-analog converter circuit after successfully determining I1 as I1=(Vin)/2R. The user is seeking guidance on calculating the voltage at point A, which is essential for applying the equation V=RxI. There are noted connection errors in the simulation schematic, particularly regarding the grounding of the input networks. Additionally, the concept of R:2R ladders is introduced, emphasizing the voltage divider characteristics that are crucial for DAC functionality. Clarification on these points is requested to aid in solving the circuit equations.
esmeco
I'm trying to work out an equation for the circuit below,but unfortunately I'm not having success.I've managed to get the expression for I1 which is:
I1=(Vin)/2R
How do I find now the expression for I2?Following the equation V=RxI where V is the difference at both terminals of the resistance I need to find the value tension at point A.How do I find that value?I've found the parallel resistance between the resistances that correspond to currents I3 and I4 which is R by I don't know how to work it from that!:confused:
Any help is really appreciated!Thanks in advance!
http://i75.photobucket.com/albums/i281/esmeco/digitalanalogicconverter.jpg
Two things. First, the simulation schematic looks like it has a couple connection errors in it. The bottom of the + input network is not connected to the - input network side or to a "ground" symbol as far as I can see. Is something missing?
Second, the trick with R:2R ladders is to see that in a ladder, the R is in series with a 2R in parallel with a net 2R. That gives you a consistent voltage divider characteristic that you can use in a DAC ladder. You might see if wikipedia or your textbook describes the R 2R ladder to get a better explanation. Hope that helps some.
