Digital modelling of Inverted Pendulum on a cart
The discussion focuses on the digital modeling of an inverted pendulum on a cart, essential for stabilizing the system at its unstable equilibrium point. The system is defined as a 4th order underactuated model with states representing the cart's position and velocity, as well as the pendulum's position and velocity. The control law consists of three components, incorporating log, signum, and exponential terms, along with a linear controller. Specific parameters and expressions are provided to illustrate the control strategy, including energy calculations and control inputs based on the system's states. The thread seeks guidance on how to effectively digitalize the system for implementation.
meiskaustubh
I am pursuing bachelor in engineering.i have a case study involving the stabilization of an inverted pendulum about it's unstable equilibrium point.
My problem is that I have to digitalize my system before i can implement it.
Can anyone tell me how to digitalize the system.
my system model is of the form y = f(x) + g(x) * u.
the system is an underactuated 4th order system with the states as the cart position(x1) and velocity(x3) and the pendulum position(x2) and velocity(x4).
the control law 'u' consist of 3 parts.the first part contains log term and signum term,the second contains signum,log and exponential terms and the 3rd is a linear controller.
for specific expressions.
Len=.4;
V = 2;
ksu = 1.63;
kcw = 2.3;
kvw = 5;
kem = 6;
n = 1.05;
E = .5*((M + m)*x3^2 + 2*m*l*cos(x2)*x3*x4 + m*l^2*x4^2) + m*g*l*(cos(x2) - 1);
E0 = 0;
ucw = kcw*sign(x1)*log(1-abs(x1)/Len);
uvw = kvw*sign(x3)*log(1 - abs(x3)/V);
uem = kem*(exp(abs(E - n*E0)) - 1)*sign(E - E0)*sign(x4*cos(x2));
u1 = -ksu*sign(x4*cos(x(2))) + ucw
u2 = ucw + uvw + uem
u3 = k*x
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
