The electric force is a vector quantity, defined by both magnitude and direction, with magnitude always being positive. Describing a vector as "positive" or "negative" is generally not meaningful, as vectors can point in various directions in space. For example, in an electric field oriented at 30 degrees from the positive x-axis, a negative charge would experience a force in the opposite direction, which can be specified in angular terms rather than as "negative." Thus, the direction of the electric force should be described using specific angles rather than labeling it as negative. Understanding the vector nature of electric force is crucial for accurate representation in physics.
