What is the Direction of the Net Force in this Loop?
The discussion focuses on determining the direction of the net force in a current-carrying loop. Participants analyze the forces acting on different segments of the loop, noting that forces on the left and right sides cancel, while those on the top and bottom segments oppose each other. The right-hand rule is suggested as a method to ascertain the direction of the net force. A participant seeks confirmation on whether their drawn direction of the net force is correct and inquires about the equation for the force between two current-carrying wires. The conversation emphasizes understanding both the magnitude and direction of forces in electromagnetic contexts.
chronicals
http://img8.imageshack.us/img8/8541/netforce.jpg
The forces on the left and right sides cancel. The forces on the top and bottom segments of the loop are in opposite directions, so the magnitudes subtract. So i have found magnitude of the net force, but how about direction?
Use the right-hand rule.
is the net force this direction?
http://img195.imageshack.us/img195/8702/doerusu.jpg
any idea?
What is the equation for the force between two current carrying wires?
i have found magnitude of direction of net force , is the direction of the net force which i draw red correct ?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
