Displacement Vector of Minute Hand on Watch: 8:00 to 8:20 & 8:00 to 9:00
The displacement vector of the minute hand from 8:00 to 8:20 a.m. is calculated by determining the angle it moves through and converting that into a linear displacement. The minute hand moves 120 degrees in this time frame, resulting in a displacement vector of approximately 1.93 cm. From 8:00 to 9:00 a.m., the minute hand completes a full circle, leading to a displacement vector of 0 cm, as it returns to the starting point. The length of the minute hand, being 2.0 cm, is crucial for these calculations. Understanding these vectors is essential for analyzing circular motion in physics.
cedwar71
The minute hand on a watch is 2.0 cm in length. What is the displacement vector of the tip of the minute hand
From 8:00 to 8:20 a.m.?
From 8:00 to 9:00 a.m.?
Hi cedwar71,
What you have tried so far?
