How Do Displacement and Distance Differ in Particle Motion Calculations?
  • Thread starter xzibition8612
  • Tags
    Displacement
In summary, the student attempted to solve a homework problem, but did not understand how to apply the math correctly. When solving the problem, they correctly calculated the velocity.
xzibition8612
142
A particle's position is described by x=2t^3-4t-5
Find its a) displacement b) distance
from t=0 to t=5
Displacement, plug in x(5)-x(0) = 230m
Distance, shouldn't it be the same thing plug in and get 230m? But book says 234m. No idea how this came about.
Hey ,
Do you know the difference between distance and displacement (Am sure you do! :-))
If a particle goes from x = 2m to x=4m and then comes back to x=3m
What is the distance traveled and displacement?
How did you calculate it in simple terms.
Something similar is happening here.
distance would be the actual physical length, so that would be 3m. Displacement is just the direct distance from start to finish, so that would be 1m.
Yes.So the basic logic you used is that you added the path length.
When the body reversed its direction at 4m ( in physics what is this point signify in terms of variables?) you didn't add the path from 4m to 3m as -1m.You added it as 1m.
Do the same on this question and you will get the answer:-)
alright man but ur concept was a simple question, this one has complicated equations and i don't know how to apply it : ======================== (
Ok.
See displacement is integration of (vdt).
Distance is integration of (|v|*dt)
And |v| is speed.
For solving the mod || you need to find intervals where v is positive and where v is negative.
so take absolute value of x=2t^3-4t-5.
then it would be -2t^3+45+5
so i take the integral of this and that's it?
For what value of t is the velocity positive?
When is it negative ?
take the negative of v where velocity is negative.
Take positive when velocity is positive.
Then integrate.
(Why do we do so?)
ok, so when x=0 is the difference. So x is negative the function is: -2t^3+4t+5, and when x is positive the function is: 2t^3-4t-5
add these two up and integrate?
but if i add it up i get 0?
No.We are interested in mod of velocity not x.take function as it is when v is positive(not neccesarily x) and multiply by minus when v is negative (not x)
No.We are interested in mod of velocity not x.take function as it is when v is positive(not neccesarily x) and multiply by minus when v is negative (not x).
And you won't get 0.
hey can you just show me the process? I'm getting very confused and I'm not sure what's going on. I think I can understand better if you show me the math. velocity would be x'=6t^2-4
Thanks man.
Thanks man.
You calculated the velocity correctly. :-)
Property of mod function is that
when f(x) is positive
|f(x)| =f(x)
when f(x) is negative
|f(x)| =-f(x).
For eg if |2| is 2.|-2| is -(-2) i.e 2 again.
Velocity is 6t^2-4.
which is positive when t belongs from sqroot (2/3) to 5 and negative between 0 to sqroot(2/3.)
So take displacement of [-(2t^3-4t-5)] for t = 0 to t=sqroot(2/3).
(or you can integrate
[-(3t^2-4)dt]
And take displacement of [(2t^3-4t-5)] for t=sqroot(2/3) to t=5.
[(3t^2-4)dt]
how did you get sqrt(2/3)??
I guess that's from x=2t^3-4t-5??
so 0=2t^3-4t-5
But how do I solve this cubic equation?
Thanks a lot man.
From 6t^2 -4 >0
We are interested in |v| not mod x.
See in the example i gave you .
From 2 to 4 m velocity was positive so you did 4-2 =2
(final position -initial position)
Then particle turned behind and velocity became negative.in moving from 4 to 3 you therefore did -(3-4)=1
And added these.
All this while x was positive.
Our sense of mod depends on velocity and not position :-)
My pleasure :-)
I hope am making stuffs clear enough :-)
Hopefully
thanks a lot man europeans are superior
Lol. I am an Indian :-)
1. What is the difference between distance and displacement?
Distance is a measure of the total length traveled along a path, while displacement is a measure of the change in position from the starting point to the end point.
2. How is distance calculated?
Distance is calculated by adding together the magnitudes of all the individual displacements along a path.
3. Can distance and displacement have the same value?
No, distance and displacement are two different measures and can have different values. However, if an object travels in a straight line, then the distance and displacement will be the same.
4. What is a vector quantity?
Distance and displacement are both vector quantities, meaning they have both magnitude (size or length) and direction. This is important because it allows us to understand not just how much an object has moved, but also in which direction it has moved.
5. How does displacement relate to velocity?
Displacement is a key component in calculating velocity. Velocity is defined as the change in displacement over a specific time period. In other words, velocity is the rate at which an object is changing its position.
