The Total Time Spent on the Trip is 9 hours.
  • Thread starter Thread starter wowdusk
    Rate Time
The total time spent on the trip includes 4 hours of walking, 1 hour for lunch, and an additional 4/3 hours for the bus ride home. The bus travels at six times the man's walking speed over a distance that is twice as long as his walking distance. The calculations confirm that the bus trip takes 4/3 hours. Therefore, the total time for the entire trip is 9 hours. This includes all segments of the journey: walking, lunch, and the bus ride.
wowdusk
A man walks for 4 hours at the rate of x miles per hour. He stops an hour for lunch and then returns on a bus to his starting point. However, the bus travels at a speed 6 times that of his walking rate and follows a route that is twice as long. "What is the total number of hours spent on the entire trip?
D=rt
I know the man spent 4 hours on the first leg and had an hour lunch, so the total time is more than 5 hours. i was trying to manipulate the D=rt formula to fir this problem, but it wasn't coming out right. I would do 2(4x)/6x, for his time on the bus because it was twice the distance he walked (2(4x)) and moving at six times his speed (6x).
You are almost there with the answer. You key missing piece is how much time was spent on the bus trip home,...
You know 'going', 4 hours.
You know 'lunch', 1 hour.
You find an expression for TIME of bus trip home,
\[<br /> time = \frac{{distance}}{{rate}}\quad = \;\;\frac{{2 \cdot 4 \cdot x}}{{6x}} = \frac{4}{3}\quad hours<br /> \]<br />
Finish the solution yourself now? Sum of three values.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
