Distance spring decompresses when friction is involved
  • Thread starter Thread starter becky_marie11
    Friction Spring
A block of mass 4.30 kg slides at 8.50 m/s and compresses a spring with a constant of 68.00 N/m while experiencing friction with a coefficient of 0.200. The initial kinetic energy is calculated as 155 J, and the work done by the system is determined using the equation W = Kf - Ki. The discussion highlights the importance of recognizing that the spring force is not constant, requiring the use of integration to find the work done by the spring. Participants clarify that the work done by the spring is expressed as W = -1/2 kx^2, while the friction force must be multiplied by distance to calculate its work correctly. The correct approach to solving the problem involves understanding the distinction between the work done by the spring and the friction force.
becky_marie11
A block of mass m = 4.30 kg slides along a horizontal table with speed v0 = 8.50 m/s. At x = 0 it hits a spring with spring constant k = 68.00 N/m and it also begins to experience a friction force. The coefficient of friction is given by μ = 0.200. How far did the spring compress when the block first momentarily comes to rest?
m=4.30 kg
vo=8.50m/s
k=68.00N/m
μ=.200
x=?
Kf-Ki=W
K=1/2mv2
Fs=-kx
Ffric=μNf
W=Fd
First I found the work of the whole system (friction and spring forces) by using
Kf-Ki=W.
For the initial kinetic energy, I used
K=1/2mv2=155J.
For the final kinetic energy, I used 0, because I'm measuring the distance after the mass came to a stop. So, plugging the numbers into the Work equation, I simply get
W=-155J
I'm pretty sure I'm on the right track so far?
Then, using
W=Fd (just multiplying the forcexdistance because both vectors are in the same direction)
I plugged in:
W=(-kx+μNf)x
I work it out to a quadratic by plugging the numbers in...
-68x2+8.44366x+155=0
I solve then for x (using the quadratic root finder on my calculator, so I'm not screwing up the quadratic..), but both of the answers it gives me are incorrect..
What am I doing wrong? Help please!
becky_marie11 said:
Then, using
Careful: That only works when the force is constant. The spring force is not constant.
Hint: What's the energy stored in a compressed spring?
Also: Careful with signs. The work done on the mass by both the spring and the friction force is negative.
welcome to pf!
hi becky! welcome to pf! :smile:
isn't it 1/2 kx2 ? :wink:
W = ∫Fdx (F dot dx, technically)
Fspring = kx
W = ∫kxdx
Wspring = kx2/2
Just to show where it came from, since W does NOT equal Fx, that is not a definition, it is a derivation of work for a constant force.
Thank you guys! I finally figured out the right answer! But when I solve for the quadratic equation, why is the distance vector only distributed to the friction force? This is what I tried to do...
W=(-1/2kx^2+friction force)*x
and this is what is right...
W=-1/2kx^2+friction force*x
Is it because the work of the spring is already in terms of "work" and the friction force isn't?
hi becky! :smile:
yes! :smile:
work done is force "dot" distance, and 1/2 kx2 is 1/2 kx (average force) times x (distance)! :wink:
Thank you!
