Distance traveled by projectile in Free Fall
The problem involves an object in free fall from a building, experiencing a constant acceleration due to gravity. The object travels half the height of the building in the last second before impact, and the goal is to determine the height of the building.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to derive the height using kinematic equations and explores the relationship between the distance traveled and time. Some participants question the steps taken in solving the quadratic equation and suggest that there may be a misunderstanding in handling the square root in the context of the problem.
Participants are engaged in exploring different methods to arrive at the solution. While some guidance has been offered regarding the quadratic equation, there is no explicit consensus on the approach taken by the original poster. The discussion reflects a mix of interpretations and methods.
There is a mention of a specific answer (57.1 m) that the original poster is trying to reach, but the path to that answer remains unclear. The discussion also highlights that different methods can yield the same numerical result, indicating potential variations in problem-solving approaches.
fluidity
An object falls from rest off a building, with a constant acceleration of 9.8 m/sec^2.
The object travels half the building in its last 1 secs of its fall before hitting the ground. What is the height of the building?
[tex]v_0 = 0[/tex]
[tex]a = 9.8[/tex]
[tex]x = x_0 + v_0 t + (1/2) a t^2[/tex]
I know that the distance traveled by the projectile for the first half of the building is given by
y= (1/2)gt^2
Now that I know that after traveling that half the height of the building it spends another second traveling the other half.
So now 2y=(1/2)g(t+1)^2
Now by arranging the first equation I get t=√(2y/g)
If I substitute that into the second equation for the variable t I get
2y= y + g√(2y/g) + (1/2)g
After this I've attempted way to get at the right answer such as using the quadratic formula but I got wrong answers. The right answer is 57.1 m, however I haven't been successful in getting to that answer.
Welcome to Physics Forums.
Well done, your equation does give the right answer. You just made a mistake somewhere in solving it.
If I had to guess, I would say that you probably forgot that this particular quadratic equation yields [itex]\sqrt{y}[/itex] so you must square the answer (and then of course multiply by 2 since you defined the building to be a height 2y)
(Quadratic equation is [itex]ax^2+bx+c=0[/itex] and so in this case you have [itex]a\sqrt{y}^2+b\sqrt{y}+c=0[/itex] and so [itex]x=\sqrt{y}[/itex] and so you'll have to square the answer you get)
Wow thanks, I didn't look at the quadratic formula in that perspective. My method of finding the answer was different compared to the Mastering Physics solution, but it gave the same exact number. So once again I want to say thanks, I really appreciate the help!
Don't worry, it happens often. I think your method was an excellent one. (The textbook solutions are not always the simplest.)
No problem! But you did most of the work :-p
  • · Replies 25 ·
  • · Replies 38 ·
  • · Replies 35 ·
