Distance travelled in n time when a body is thrown upwards
  • Thread starter Thread starter Govind_Balaji
    Body Time
A stone thrown vertically upward with an initial velocity v_0 travels a distance of \(\frac{5v_0^2}{8g}\) in the time \(\frac{1.5v_0}{g}\). The time to reach maximum height is calculated as \(\frac{v_0}{g}\), leading to a remaining time of \(\frac{v_0}{2g}\) for the descent. Using kinematic equations, the initial velocity at the midpoint of descent is \(\frac{v_0}{2}\), and the distance covered during this segment is derived as \(\frac{v_0^2}{8g}\). The total distance combines both ascent and descent, confirming the final answer. The discussion highlights the importance of careful arithmetic in solving physics problems.
Govind_Balaji
Here is a question in my textbook. I saw the answer, but no explanation was there.
A stone is thrown vertically upward with an initial velocity v_0. The distance traveled by it in time \frac{1.5v_0}{g} is ______________.
Answer is \frac{5v_0^2}{8g}.
Max. height reached by a body thrown upwards with an initial velocity v is \frac{v^2}{2g}
Time taken to reach the max.height with initial velocity v=\frac{v}{g}
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn2/t1.0-9/1382433_1591373084420691_3016752318298202408_n.jpg
Time taken to travel AB+BC=\frac{1.5v_0}{g}
We know that time taken to travel AB=\frac{v_0}{g}
∴Time taken to travel BC=\frac{1.5v_0}{g} - \frac{v_0}{g}
===================\frac{v_0}{2g}
Initial velocity at B in BC=u=0
Acceleration=a=g
We know <b>v=u+at</b>
v=0+g.\frac{v_0}{2g}=\frac{v_0}{2}
v^2=u^2+2as
\frac{v_0^2}{2^2}=0^2+2.g.s
\frac{v_0^2}{4}=2gs
s=\frac{v_0^2}{8g}
Distance of AB+BC=\frac{v_0^2}{2g}+\frac{v_0^2}{8g}
==============\frac{4v_0^2}{8g}
man you made a slight arithmetic mistake in the last line.
Oh yes! Thanks. I am happy at least I made only arithmetic mistake and not a concept mistake.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
