Divergence of a cross product help
simba_lk
I need to prove the identity: \nabla(\vec{A} \times \vec{B})=\vec{B} \bullet(\nabla \times \vec{A}) - \vec{A} \bullet( \nabla \times \vec{B})
I need to prove for an arbitrary coordinate system, meaning I have scaling factors.
The proof should be quite straight forward if you use the levi chevita symbol but so far this is what i have:
\nabla(\vec{A} \times \vec{B})=\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}) = \frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}) \ast \hat{e_{i}} \bullet \hat{e_{i}}
But I can't see how to take it into the desired format
I think I should squeeze in a kroncker delta somehow, but I'm not sure.
Do you know how to do the proof without the scaling factors?
Yes, I just tried and it works fine even without the addition of unit vectors and the delta.
My problem is that I cannot take the scaling factors in or out of the derivative.
Perhaps I missed somthing?
Would these scaling factors perhaps be constants? Or are they functions of one or more of the coordinates?
Of course they are functions, consider for instance spherical coordinates
I'd try simplifying ##\frac{h_1 h_2 h_3}{h_i}## to ##h_j h_k##. Then I think you just have to apply the product rule and grind it out.
This is my idea too but how can take the scaling factor out of the derivative?
I don't know why you want to fool with h or moving it. Just use the chain rule to hold each vector fixed in turn.
$$\dfrac{\mathrm{d}}{\mathrm{dt}}u=\dfrac{\mathrm{dx}}{\mathrm{dt}}\dfrac{\partial}{\partial x}u+\dfrac{\mathrm{dy}}{\mathrm{dt}} \dfrac{\partial} {\partial y}u$$
in your example
$$\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}) =\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} (B_{k})_\mathrm{fixed}) +\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} (A_{j})_\mathrm{fixed} B_{k}) $$
Ok but this doesn't prove the identity, if you look at the definition of the curl in curvilinear coordinates
Once variables are fixed they can move through derivatives and the identity is easily proven
$$\frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} B_{k}) =(B_{k})_\mathrm{fixed} \frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} A_{j} ) +(A_{j})_\mathrm{fixed} \frac{1}{h_{1}h_{2}h_{3}} \frac{\partial}{\partial x_{i}}( \frac{h_{1}h_{2}h_{3}}{h_{i}} \epsilon_{ijk} B_{k}) $$
Hint:
$$\nabla\cdot(\vec{A} \times \vec{B})
= \frac{1}{h_1 h_2 h_3} \frac{\partial}{\partial x_i} [h_j h_k \epsilon_{ijk} A_{j} B_{k}]
= \frac{1}{h_1 h_2 h_3} \frac{\partial}{\partial x_i} [\epsilon_{ijk} (h_j A_j) (h_k B_k)]$$
thanks a lot
