Optical Home-Made Fiber Optics: Alternatives to Food Jelly?
Homemade fiber optics can be created using food jelly, but for high vacuum applications, alternatives are needed as jelly is unsuitable. Transparent epoxy from hardware stores is suggested, though concerns about outgassing in high vacuum environments are raised. Standard fiber optic cables may also be problematic due to outgassing. The discussion highlights the potential use of line-of-sight optics and mirrors as a viable solution. The original poster mentions that their project is educational and not intended for serious lab use, indicating a focus on experimentation rather than professional application.
Ravaner
Hello. I know how to realize an homemade fiber optic using some food jelly. Are there other materials, at amateur grade; to replace jelly ? ( NB this item has to be used in high vacuum, and jelly is not convenient for this use)
Is this to work in the visible?
You could try a transparent epoxy from a hardware store.
Claude.
P.S. I'm interested in how you make fibre optics with jelly. Do you extrude the jelly through a hole or use a cast of some sort?
Thanks for reply. Yes I'm working in invisible area. To use jelly it is possible to introduce it in a cast, but it's just for educational application not really serious for lab. Sorry for the attached doc, it's in French ...
You can buy plastic fibre quite cheaply. Try ebay?
Materials like epoxies, etc., will outgas in a high vacuum. Even standard FO cables may outgas too much for high vacuum work. Can you just use line-of-sight optics and mirrors? Can you say more about your setup?
