DME gas through the regultor problem
  • Thread starter Thread starter jkim6881
    Gas
The discussion centers on the challenges of using DME in a combustion experiment, particularly the freezing issue occurring at the regulator due to the cooling effects of vaporization and expansion. Proposed solutions include adding heaters near the regulator and using a flexible line between the DME bottle and the regulator, which can be heated or submerged in hot water. The flexible line method is favored since it avoids electrical connections at the bottle. Suggestions also include drawing liquid DME instead of vapor to mitigate freezing, similar to propane systems that utilize heat exchangers or direct flame to vaporize the liquid. Overall, the conversation seeks effective solutions to prevent the regulator from freezing during the experiment.
jkim6881
I am currently setting up a combustion experiment and I encountered a problem with a fuel I am using.
For this set up, I am using DME and thread type is POL.
After DME is evaporated in the bottle and pass through the regulator, it gets really cold that it almost freezes over in few minutes. (This is because of latent heat of vaporization within the bottle, and for regulator - isentropic expansion of the gas, cools and joule thomson cooling effect)
Thus, this needs to be fixed.
For this issue, the one proposed method is putting heaters near the regulator so it does not freeze
Other method is placing a flexible line between DME bottle and regulator. Flexible line from the bottle to the regulator (In line heaters)
Heat up these line with the heater is or put the flexible line in the hot bucket of water is suggested.
Since the bottle connection doe not involve the electricity, this option is came out to be most relevant method. But problem is water needs to be replaced several times during the experiments.
So I wonder whether there is other solution or suggestion for this issue.
Thanks
I will assume that DME is similar to propane in properties of evaporation and liquification. Do a search on propane systems and you will probably find a solution. First hint would be to take liquid out of the tank instead of vapor. That solves the tank freeze over problem. Hot air balloons as well as other equipment that uses propane run the pipe carrying the liquid right through the flame to vaporize it. Vehicles that run on propane have a heat exchanger using the engine coolant to accomplish the same thing.
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
