Do different paths of an electron interfere with each other?
  • Thread starter Thread starter haael
    Electron
haael
Suppose we have a double-slit experiment. A particle, say electron, splits into two paths, then it lands on a screen. An interference pattern appears.
Now, can the two "instances" of the same electron interact, say repell each other?
Imagine this setup: we have an electron beam and a splitter that divides it into 2 beams. If the two beams were projected on a screen, they would interfere, but that is not what we do. Instead we focus the beams and shot them against each other. If they were two "normal" separate beams, the electrons would scatter and produce photons that can be detected. Will the same effect be observed with the beams that come from the splitting?
My wild guess is that a "half" of the wavefunction of the electron travels in each beam. When the "halves" should collide, they will produce a "quarter" of a photon. So, the intensity of light from the entangled beams should be 4 times smaller compared to two colliding independent beams. Is that correct?
No, it doesn't. The electron will leave a single point on the screen. Interference can only be visible after many electrons have gone through the slits.
No. It that was the case, it would already have been observed in actual experiments (which show no difference between charged electrons or uncharged neutrons).
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I asked a question related to a table levitating but I am going to try to be specific about my question after one of the forum mentors stated I should make my question more specific (although I'm still not sure why one couldn't have asked if a table levitating is possible according to physics). Specifically, I am interested in knowing how much justification we have for an extreme low probability thermal fluctuation that results in a "miraculous" event compared to, say, a dice roll. Does a...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
