Do Frames Affect Dimensional Units?
  • Thread starter Thread starter BitWiz
    Frames Units
BitWiz
Say a ship is coasting in space at an arbitrary speed and velocity with respect to an observer. If a joule of energy (generated on the ship) is used to instantaneously accelerate the ship:
From an external observer, the acceleration and delta-v observed is dependent on the ship's initial speed (not velocity), correct? The higher the measured speed, the less acceleration and delta-v observed? If I apply a second joule in a separate event, both the acceleration and delta-v will appear to be less than the first time for that observer. Correct?
From within the ship, the perceived acceleration will be the same for both events? If I observe a destination star directly in front of me, the delta-v's will also appear to be the same with the relativistic inertia, time, and length effects canceling out?
Say the ship is already accelerating at a steady rate, and I again apply an extra joule in two events. From the ship's frame, will both events now be different, the second being of less magnitude than the first? What will the external observer see?
Finally, do frames affect or have dimensional units?
Say that two observers each have their own frame and a frame in common. If their individual motions have fixed vectors such that the two observers appear fixed in space with respect to each other, then their individual frames and the common frame are the same.(?) Newtonian mechanics apply. Is it fair to say that this state has a unit dimensional term of γ0?
If the vectors do not match, then motion will appear in the common frame, and relativistic effects will apply, but the individual frames are unaffected, and to the observers, interchangeable. Is this correct? Is it fair to say that the common frame has a unit dimension of γ1 but the individual frames have a γ0 dimension?
If one of the vectors is changing over time, then each observer will appear to observe an identical force being applied to the other, but only one will be able to measure the force with an accelerometer. Correct? If so, should this accelerating frame be described with different dimensional units even though from the observers' points-of-view, all else is the same. (?) Would we now have a unit dimension of γ0 for one observer, γ1 for the other, and γ2 for the common frame?
Thank you kindly for your comments.
Chris
It matters how this energy is used.
It depends on the acceleration method, the speed, the direction of the spaceship and the direction of the acceleration.
Again, depends on how you spend that 1J.
What does that mean?
Which frame, what do you mean with "in common"? Observers do not own frames.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
