Does an orbiting satellite speed up as it falls towards earth
The discussion revolves around the behavior of a satellite in orbit around the Earth, specifically whether it speeds up as it falls towards Earth. The original poster explores the relationship between gravitational and centripetal forces, questioning how changes in orbital radius affect velocity and energy conversion.
  • The original poster attempts to understand the mathematical relationship between gravitational force and orbital speed, while questioning the nature of velocity changes as a satellite descends. They also inquire about the implications of maintaining orbital speed when moving to a higher orbit.
Participants have provided insights regarding the nature of orbits and the effects of atmospheric drag on satellite speed. Some guidance has been offered regarding energy conversion, but multiple interpretations of the satellite's behavior are still being explored.
There are assumptions regarding the absence of external forces and the simplification of Earth's mass distribution. The discussion also touches on the effects of atmospheric drag on real orbits, which may complicate the idealized scenarios presented.
LotusTK
(sorry for spelling of Earth, had to be to be done to fit it in lol)
Does a satellite in orbit around the Earth speed up as it falls towards Earth?
I understand why the satellite speeds up mathematically. If we equate the centripetal force equation and the equation for gravitational force (because the centripetal force on the satellite is the force of gravity) we end up with
v=sqrt( GM/r)
G = gravitational constant, M = mass of Earth, r= radius of circular motion from centre of earth)
So if you decrease r, v increases, and vice versa.
Is it just simply because the gravitational potential energy of the satellite is being converted into kinetic energy? So instead of just increasing velocity directly towards the Earth like when you drop a ball, its tangential/orbital velocity increases?
I picture the satellite just increasing its velocity directly towards Earth, rather than actually increasing the speed with which it orbits. But then the above formula suggests otherwise.
Also, would i be correct in saying:
If the satellite were to maintain the same orbital speed, but was pushed up into a higher orbit without increasing or decreasing its orbital speed, the satellite will no longer be able to maintain its orbit and begin to spiral away from Earth, because the centripetal force requirement to keep the object in that particular orbit at that particular speed is no longer able to be met by gravity?
Thanks
Without external force and approximating Earth as spherical symmetric mass, the satellite just keeps orbiting in its orbit. If you push it a bit, it goes to a new orbit. No spirals.Real orbits with atmospheric drag speed up as their orbit decays, and it is a simple conversion of gravitational to kinetic energy and heating the atmosphere. At some point drag wins, they get much slower and fall back or burn up rapidly.
Real orbits with drag speed up as their orbit decays, and it is a simple conversion of gravitational to kinetic energy and a bit of friction. At some point drag wins, they get much slower and fall back or burn up rapidly.
And is this because of the change of gravitational potential energy to kinetic energy? And when you say speed up, you mean the speed with which it is orbiting, right?
Yes, see the previous post.
Sure.
  • · Replies 39 ·
