Does the Presence of Rc Affect the Voltage Gain in a Common Collector Amplifier?
In a common collector amplifier, the presence of a collector resistor (Rc) does not affect the voltage gain, which remains approximately equal to 1. However, Rc can reduce the maximum output voltage swing. The emitter resistor, if present, stabilizes the Q-point and limits current flow, impacting current gain but not voltage gain. The configuration primarily serves as a buffer, emphasizing that high gain is not the goal. Overall, the discussion clarifies that while Rc influences output characteristics, it does not change the fundamental voltage gain of the amplifier.
eric336
Normally in common collector amplifier, Rc (collector resistor) is absent or otherwise it is short circuited by capacitor.
My question is: If Rc is present and not short circuited, does it affect the voltage gain? If it does, how it affects? Appreciate if someone can present clearly in equivalent circuit. Thanks.
No.
If it does, how it affects?.
It affects (reduces) the maximum output voltage swing but does not alter the gain.
Thanks uart, appreciate it very much.
Ask yourself what the resistors do in a transistor amplifier.
Base resistors establish the DC level of the base.
The emitter resistor (if present) raises the voltage of the emitter to some desired level depending upon base bias level.
It also serves to limit the current flow through the transistor.
If there is no emitter resistor the transistor is at risk of excess current flow unless there is a collector resistor.
The above is true of all configurations including a CC configuration - also called an emitter follower.
The voltage gain of the emitter follower is just less than 1. The output voltage swing is developed across the emitter resistor in parallel with the load resistor or just across the load resistor if no emitter resistor is present.
So an emitter resistor affects the current gain as it forms part of the (effective) load. However it does not affect the voltage gain.
I knew the role of emitter resistor is to stabilize Q-point.
As far as I concern, the voltage gain of CC should approximately equal to 1, after all CC is just used as buffer, we don't want so much gain. Is it possible it is less than 1, like you said?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
