Does this involve calculus? im confused help please
  • Thread starter Thread starter pringless
    Calculus Confused
The discussion clarifies that calculus is not necessary to solve the problem of finding the distance of closest approach between two objects moving along the x-axis. The positions of the objects are given as functions of time, and the difference between these functions can be expressed as a quadratic equation. By graphing the two equations and their difference, one can visually identify the point of closest approach, which corresponds to the minimum value of the difference. The method involves determining the coefficients of the quadratic to find the vertex, representing the time and position of closest approach. Understanding the graphical representation is key to solving the problem effectively.
pringless
Hint: x_1 and x_2 never have the same value. The x-coordinates of two objects moving along the x-axis are given below as a function of time t. x_1 = (4m/s)t x_2 = -(25m) + (8m/s)t - (2m/s^2)t^2 Calculate the magnitude of the distance of closest approach of the two objects.
Hi pringless,
no, you do not need calculus to solve this.
Let's call x(t) = x1(t) - x2(t).
This is just quadratic in t (the graph is a parabola).
All you got to do is find the lowest (or highest) point of the parabola.
Let's call that point (t0, x0), then we can write
x(t) = a(t - t0)2 + x0.
You can find a, t0, x0 by matching the coefficients on both sides. OK?
im sorry...i don't really understand what u mean
Pringless,
Graph the two equations. That will show you position of each particle as a function of time.
If you then subtract one from the other, you'll have the difference between the two. If you graph that, you'll see the difference as a function of time. You'll see that it will go down and then go back up. The closest approach is where the difference is the smallest.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
