Double integration using trig term
glog
\int^1_0 \int^1_y sin(x^2) dx dy
This equation cannot be integrated nicely, so I tried to reverse the order of integration:
\int^1_0 \int^1_x sin(x^2) dy dx
However this only helps for the first step, since when we intregrate by y, we get:
\int^1_0 sin(x^2)-xsin(x^2) dx
I'm stuck... again! Any ideas?
Your limits in the new double integral is incorrect. If in doubt, look at the original double integral and draw a picture of the region enclosed by the limits. Then try to express the limits of the double integral in the reversed order of the same region.
Alright so perhaps the bounds are then: \int^1_0 \int^x_0
In which case, my integral simplifies to:
\int^1_0 x sin(x^2)
Which becomes:
-1/2 cos (x^2) | 1_0
This make sense?
Yep, you got it.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
