Doubt with rotating body and force
The discussion centers on the behavior of a rotating bar system with no friction, where an initial force causes the bar to rotate. Once the force is removed, the bar continues to rotate at a constant angular velocity due to the absence of external forces, with each point experiencing centripetal acceleration. The conversation highlights that while the bar maintains its motion, internal forces are responsible for the acceleration experienced by its points. It is clarified that for an object to continue rotating indefinitely in space, it requires an initial torque, but will not need continuous force to maintain its angular velocity. The principles of net force and torque are emphasized, illustrating how they relate to motion and acceleration in rotational dynamics.
carlitos_30
Hello.
Let's image a bar. In one side is attached to a body so the bar can rotate over this axis. There is no friction between the two bodies. The system is at rest in t=0. A force acts forming a 90° angle with the bar. The bar moves and begin to rotates. The force dissapear.
There is no force acting on this system, but I think that the bar doesn´t keep moving forever since its changing his direction every moment, hence there is an acceleration present, but if there is an acceleration present a force should be acting in the system which contradicts the assumption.
¿How this can be?
Do you think you can create a pic? I'm not sure of the setup.
Likes carlitos_30
Justo imagine there is no Gravity or another force.
Something like this:
The dashes represent the bar.
I----------------
If I understand you correctly, it is a cylinder that rotates along its axis and no other movements are going on.
If that's the case, every point of the cylinder is accelerating at right angle to its direction of motion (aka centripetal acceleration). In this special case, the speed is preserved. But yes, forces are present. If the cylinder rotates too fast, it will fall apart.
Likes carlitos_30
I----------------
Where is the joint axis? Where is the froce?
In any case:
- If you exert a net force, the whole thing will start moving, and will keep moving after the force is gone.
- If you exert a net torque, at least some parts will start spinning, and will keep spinning after the torque gone.
Likes carlitos_30
I think OP is asking this: if an object is rotating, in this case at constant angular velocity after the initiating force is removed, then each point on the object is constantly changing direction, so is accelerating. What force is providing the acceleration?
Likes carlitos_30
In that case it would be internal forces. Without external forces the center of mass of the whole thing has no acceleration.
Likes carlitos_30
In any case:
Moving at constant speed?
In this example, a force is applied and the wrench start to move. When is moving, the 200 N force isn't applied any more? Is just applied at the beginning? Or I have to assume that the 200 N force is applied every instant the wrench is moving?
The center of mass would be at the center of the bar and I imagine is moving every instant, changing the velocity vector, hence there is an acceleration in the center of mass.
I was talking about net force and net torque. Are the 200N the only force acting on the wrench?
I was talking about the center of mass of the whole isolated system, not just the wrench.
Likes carlitos_30
It will keep moving forever?
Yes.
To keep the wrench rotating or anything rotating with no friction, the 200 N force has to be applied every instant or only at the beginning?
The following assumes there is no friction: If 200N is the net force, it will cause angular acceleration. As long as a net force is applied, the angular velocity will continue to increase. If the force is removed and the net force is 0, the wrench will continue to move with a constant angular velocity, equal to what it was when the force was removed.
For a particle, Newton's second law says F = ma, net force equals mass times acceleration. As long as there is a net force, there will be acceleration, or an increase in the velocity. If the net force F is zero, the acceleration is zero and the velocity is constant.
For rotational motion of a rigid body, there is an analogous law: T = Iα, the net torque, T, equals the moment of inertia, I, times the angular acceleration, α.
Likes carlitos_30
carlitos_30 said:
Yes.
Really? The screw exerts no forces on the wrench?
Yes, outward the wrench due to Newton third law.
May I conclude safely that the ridig body will keep rotating forever when only centripetal and the reaction to this force in the pivot(centrifugal?) are acting in the body?
carlitos_30 said:
Yes.
A wrench turning a bolt has friction so a force (torque) is needed to keep it turning. If you remove the torque the friction will cause it to slow down a and stop.
An object floating in space has no friction. A torque has to be applied to start it spinning but it will keep spinning after the torque is removed.
The general case is...
Torque = moment of inertia * angular acceleration
Or
Angular acceleration = Torque / moment of inertia
Where Torque is actually the net torque (eg the applied torque - friction torque).
Likes carlitos_30
