Draw heaviside and ramp function
The discussion focuses on plotting the signal y(t)=3u(t+3)-r(t+2)+2r(t)-2u(t-2)-r(t-3)-2u(t-4) using unit step (u) and ramp (r) functions. Participants suggest breaking the problem into parts, analyzing u-components and r-components separately before combining them. There is confusion regarding the activation points of the u-functions and the correct representation of the ramp functions, with clarifications provided about how to interpret the amplitude and time intervals for each function. The importance of manually plotting the graphs is emphasized, as well as understanding the behavior of the ramp functions, which differ from the step functions. Overall, the conversation aims to clarify the process of combining these functions into a cohesive graph.
ongxom
Plot this signal
I tried to draw each single function, but do not know the way to plot for the whole signal like the bottom graph
Try breaking the problem down into 2 parts--a graph resulting from only the u-components, and another from only the r-components. Post what you get.
Only for u function
Only for r function
What things I have to do next to get the correct graph ?
Your u-function looks right. Your r-function has a problem with the rightmost segment. Fix that and then just add them together. It may be easier to start with the r-function and then add the offsets from the u-function. You may even be able to do it visually if your x-axes are the same scale.
Let me ask some question first :
Both of graph is plotted using wolframalpha, for the u-functions :
y(t)=3u(t+3)-2u(t-2)-2u(t-4)
The 3u(t+3) function is correct, but for -2u(t-4), i think it should have a line starts from (2;-2) but the graph only shows a line starts from (4;-1), and where is the line for -2u(t-2). Where does the line start from (2;1) to (4;1) come from ?
Wolfram alpha would be good for checking your work, but you should first try to do the graphs manually.
Why would you think that? The function -2u(t-4) "activates" at t=4.
(4,-1) is correct.
That would be from the third time interval (I3), below:
Realize that y(t)=3u(t+3)-2u(t-2)-2u(t-4) is composed of 4 time intervals:
I1: -∞ < t < -3 [nothing is happening because no u-function is "active" --for amplitude, think 0]
I2: -3 <= t < 2 [3u(t+3) is the only "active" --for amplitude, think 3]
I3: 2 <= t < 4, [3u(t+3) AND -2u(t-2) are both "active" --for amplitude, think 3-2]
I4: 4 <= t < ∞, [3u(t+3) AND -2u(t-2) AND -2u(t-4) are all "active" --for amplitude, think 3-2-2 ]
In the definition of unit step function, the function-2u(t-4) should be
-2 if t-4>0 and 0 if t-4<0
so it should start from (4;-2), am I right ?
Yes. Technically its: -2 if t-4 >= 0 and 0 if t-4 < 0
Another example x(t)=2u(t)-u(t-1)-u(t+1)
For 2u(t) = 2 if t>0 and 0 if t<0, a line will start from (0;2)
For -1u(t-1) = -1 if t>1 and 0 if t<1, line starts from (+1;-1)
For -1u(t+1) = -1 if t>-1 and 0 if t<-1. line starts from (-1;-1)
I tried to plot all thing above in a graph, but does not know how to combine them into one. The correct graph have lines start from (-1;-1) to (0;-1) and (0;1) to (1;1).
I am stucking at see the way 2u(t) represent in the graph.
You don't need any special tools to solve these kinds of problems. A pencil and some graph paper will do the job.
Not really. (-∞;0) to (-1;0) to (-1;-1) to (0;-1) and (0;1) to (1;1) to (1;0) to (∞;0)
2u(t) is an additive term in the composite graph. You won't "see it" in the graph as you would if it stood alone. It is responsible for the 2-unit jump from (0;-1) to (0;1).
Before jumping all over this and other examples, did you understand what I wrote in post #6? If not, what is not clear? I am trying to understand what you don't understand about the OP so please focus on post #6 for now.
Thank you, I got the #6. Now come to the ramp function, I have tried to separate time intervals but it seems there is nothing like the amplitude for heaviside, it doesn't work.
What doesn't work? The time intervals for the combined ramp functions can be obtained from inspection:
yramp(t) = -r(t+2) + 2r(t+0) -r(t-3)
You know, maybe you are still trying to do too much all at once. Why not just take two of the function terms and add them together:
yramp-first-2-terms(t) = -r(t+2) + 2r(t+0)
What would that look like?
Let me do it :
-∞<t<-2 : No signal, 0 for amplitude.
-2<t<0 : -r(t+2) is active at t=-2, -1 for amplitude.
0<t<3 : -r(t+2) and 2r(t) are both active, 2-1 for amplitude
3<t<+∞ : -r(t+2) and 2r(t) and -r(t-3) are all active, 2-1-1 for amplitude.
I have no idea what the graph would look like, the u-functions only have lines paralled with t-axis.
So jumping ahead (against my advice :frown:), you are now working on yramp(t) = -r(t+2) + 2r(t+0) -r(t-3).
True.
False. r(t) is the unit ramp function, with amplitude 0 for t<0 and a "ramping" output for t >= 0 (output starts at zero and increases linearly with a slope of 1).
-r(t+2) starts ramping at t=-2 with a slope of -1.
"amplitude" is wrong. You are thinking about the behavior of the u-function.
Again, the "constant amplitude" concept only applies to u-functions.
You started out this post with a collection of horizontal and diagonal lines. Those diagonal lines are the the result of the r-functions. By the way, the red dash-dot-dot-dashed line is not shown correctly (it should start at t=3).
