I Driven forced oscillation wmax for Amax stuck on maths ><
The discussion centers on finding the maximum amplitude of a driven oscillator by determining wmax through the derivative of the amplitude equation. The user has derived the amplitude formula but struggles with simplifying the derivative to find wmax. A suggestion is made to minimize the expression instead of maximizing the amplitude, which could simplify the process. The user is encouraged to use the chain rule to show that both approaches share a stationary point. This method is expected to lead to the desired expression for wmax more easily.
NMS2
Hello
Need some help simplifying this. In relation to a driven oscillator I am looking for wmax for which the amplitude is maximum. I understand the theory and I am just missing something with the maths and I know its probably something so stooooopid I am missing >< I'm taking the derivative but I end up with something pretty convoluted and I know this is meant to be relatively simple but I just can't get it... I am staring at it too long, need someone else to look at it.
I have worked out the Amplitude as:
A= fo/m/sqrt((wo2-w2)22w2)
Then I attempted dA/dw to get wmax for which A is max and set to zero but it all got a little out of hand
-((fo/m)(2)(wo2-w2)(-2w)+2γw2))/((2)(wo2-w2)22w2)3/2)=0
I want to work with this expression because I understand where it came from and it makes sense to me. I just can not remember how to simplify something like this and it is going to keep me awake at night
I know that its supposed to boil down to this:(but I can not get my dA/dw to look like this. )
wmax= (wo2-(γ2/2))1/2
my goal is to figure out how to make my expression look like this
>< please help
Thank you
To make life easier, instead of trying to maximize ##\frac{1}{\sqrt{(\omega_{0}^{2} - \omega^{2})^{2} + \gamma^{2} \omega^{2}}}##, instead try minimizing ##(\omega_{0}^{2} - \omega^{2})^{2} + \gamma^{2} \omega^{2}##. I guarantee you'll sleep easier. :smile:
If you're dead-set on getting your expression to work, then try substituting ##f(\omega) = (\omega_{0}^{2} - \omega^{2})^{2} + \gamma^{2} \omega^{2}## and using the chain rule to show that they share a stationary point.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
