Q_Goest said:
Hi venik,
As the others are trying to explain, the drivetrain with a lower inertia doesn't change the engine power. It changes the amount of power stored in the drive train during acceleration. The increase in measured power during acceleration may very well differ from the measured power under constant load, but that difference is dependant on how much power is being stored in the drive train during acceleration. If one measures power at constant RPM, drivetrain inertia will have no affect on the measurement. If measured during acceleration, it will drop from this constant RPM measurement by the amount of power stored by drivetrain inertia.
You are correct in suggesting that by reducing drivetrain inertia, more of the engine power is transferred into accelerating the vehicle. Note however, that the difference between the power going into accelerating the vehicle and the power produced by the engine is going into things like drivetrain inertia and also frictional losses. Note also that the drivetrain inertia is stored energy just as a flywheel stores energy, it is not lost as heat like frictional loads are.
we don't want to find out the engine's horsepower on a dyno, most importantly we want to TUNE the car on a dyno, but as far as numbers go, hp to the wheels is more important than hp at the flywheel. As I've stated before we can increase what it's putting to the ground without changing the engine's power and by decreasing frictional and/or inertia losses. For frictional losses we can coat the drivetrain with very smooth material, and for inertia losses, we use carbon fiber, or other lightweight/strong materials. Still frictional loss is no competition for drivetrain loss, unless you're rev limiter is at 8000 rpm, I think you are regurgitating what you heard about engine dynos, mostly frictional loss there because there is almost no mass between the crank and the flywheel.
"If you don't know it and use an uncontrolled accelerating dyno, you haven't learned anything useful - all you learned is how your car performs on that dyno and measuring the same car on a different dyno may give you completely different results."
I've noticed that switching from one dyno to another, I may dyno 500 on one, and 560 on another. But i don't go to a dyno to find my horsepower, I go there to get a professional to tune it, and I go to the same one every time. Yes if i went to another one i would get different numbers, but as long as I redyno on the same dyno and my number's increase, my power at the wheels is increasing.
"Hmm... so when the car is going at constant speed (zero acceleration) it doesn't need any power? That's strange, I just tried driving 10 miles down an empty road with the engine switched off, but it didn't work for some reason."
in a vacuum, frictionless space it would be possible without power, but you're working against air resistance, gravity, etc.
"Assuming that what you measure on a rolling road will read directly across to real performance is very poor physics, whether you learned it "from one of the top engineering schools in california" or wherever."
As i said before, if it increases the acceleration of the drum, it will increase the acceleration of the car, and acceleration takes power. Nobody said it will read directly to real performance, however if the dyno tells me I'm gaining power consistently, then I'm doing something right.
"So the power you measure is always off by some fraction depending on the design of the dyno and your drivetrain inertia. That fraction is not physically relevant."
On a roller dyno, the drive train should be completely excluded when you are trying to find what you are putting
to the wheels, when you go out back on the road you are taking that drivetrain with you so there is no sense in calculating what your horsepower would be without it. having said that, who cares? If i wanted to find out exactly how much it is increasing my power to the wheel's maybe i would care, but if the power is increasing on the same dyno, I got my answer and i can use it for whatever proving i want regardless if they are exact numbers, they
increased the average hp, that is the point I'm trying to make.
It seems like everyone is flaming me for off-topic things, so i think my work here is done, sorry to piss everyone off especially you physic's majors. Drive train inertia = lost power correct?
