When Will You Hear a Stone Dropped in a 240m Deep Mine Shaft?
  • Thread starter Thread starter linhy
    Shaft
To determine when a stone dropped in a 240m deep mine shaft will be heard hitting the bottom, the speed of sound at 23.5°C is calculated to be 345.1 m/s. The time for the stone to fall is calculated using the formula D = (1/2)gt², resulting in approximately 6.93 seconds. The time for the sound to travel back up the shaft is calculated using T = D/V, yielding about 0.695 seconds. Adding both times together gives a total of approximately 7.623 seconds. This combined time is deemed reasonable for the scenario presented.
linhy
one last problem..
IF you dropped a stone into a mine shaft that is 240 m deep. HOw soon after you drop the stone do you hear it hit the bottom of the shaft? Assume that temperature for this situation is 23.5 celcius
So.. in order to get the wave speed i plug in
V= 331 m/s +(.6(23.5 C))
V= 345.1 m/s
I know that T is equal to the inverse of the frequency.. however i don't know how to get the frequency. Does anyone have a clue?
You don't need the frequency for this. You know the speed of sound, and the distance it travels. From that, you can work out the time it took for the sound to get back up the shaft.
You must also consider the time it took the stone to drop to the bottom of the shaft. That is important in your answer.
so i have D= (1/2)gt^2... i solved for t and i got 6.93 second it took for the stone to get up. Then I used V = D/T .. so T = D/V.. hence.. afterward i got .695.. so i add the two answers i got together ...and got 7.623s. Does this answer sound resonable?
It looks OK to me.
well.. it looks reasonable to me too? thx! ^_^
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
