Dumbest idea I've even heard in my life
  • Thread starter Thread starter Curl
    even Idea Life
The discussion centers around a proposed concept for heated roads designed to melt snow using solar energy. Participants express skepticism about the practicality and viability of this idea, highlighting several key concerns. The high costs associated with the materials and technology required for construction are a primary point of contention. Concerns are raised about the efficiency of solar panels when covered by snow, the brittleness of glass as a road material, and the challenges of maintaining and repairing such roads. Critics argue that the energy needed to melt snow far exceeds what could be realistically generated by solar panels, especially during winter conditions. They suggest that traditional methods, such as snow plowing and using salt, are more effective and economical. Some participants propose alternative solutions, such as Teflon-coated roads to allow snow to slide off, or simply improving vehicle capabilities for winter driving. Overall, while there is recognition of the innovative aspect of the idea, the consensus leans towards it being impractical and overly complicated compared to existing snow management methods.
Curl
Check this out:
http://edition.cnn.com/2011/TECH/innovation/01/19/smart.roads/?hpt=Sbin
Tell me if this is anything more than retarded. I don't mean to sound insulting, but this cracked me up, that's how sad it is. There are so many problems with this, I don't even know where to begin. I'm speechless. What do you think?
It's about time! How, exactly,is this idea dumb ?
Well given the materials, it's going to cost a fortune. And that's before we get to the technology.
If it's overcast, the system won't generate much heat. If the temperature then drops low enough to counter this small amount of heat production, the snow will build up, rendering the system useless.
I nice idea, but I'm not sure how viable it is. Far too many problems to overcome.
For sure, the guy who has designed this contrapment must have ample evidence that it will work. He must also have considered these factors; that's what validational experiements are for!
I don't know the full details of this device so I believe it would be ignorant on my part to completelt discredit the idea.
Besides, as long as the money needed to purchase this system would be equivalent to the cost of snow removal over 5-10 years I think it is worth it.
If you read the article, he hasn't even tested what temperature they'd need to output in order to function. This is all just some idea at the moment.
Remember, you have to include the cost of maintenance and replacement - including digging roads up for utility works - which isn't cheap with current roads.
I'm not discrediting it, simply outlining the various problems that need to be overcome.
ROFL, this idea is so retarded is sad.
1) Glass roads? Glass is brittle. If you lay it in plates, there will be dislocations and cracks forming. Asphalt is dumped out of a truck and rolled. How do you make curved roads out of glass? Crests and hills are everywhere, and so are turns, banks, etc. How do you patch up this when it cracks/chips? With asphalt its easy. How do you ship all this material to build large roads? What happens when it rains and you slide off?
2) Laying solar cells underneath? Really? That is just completely stupid. Why spend the extra money when you can use a desert to put your cells on, it is much much more economical than laying it underneath roads. You might as well put them on the side of the road. The problem with cells is that they are expensive and weak (aka crap), the problem is not that there is no space for them.
3) The best one for last: Heating up roads and melting snow. HAHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAAAAAAAAAAAAA! TEARS OF LAUGHING!
If there is enough energy from the sun to melt the snow, why doesn't the sun melt it directly? Even if cells were 100% efficient this would be a dumb idea. Looks like somebody believes in perpetual motion and free energy BS. He should lose his license.
Brittle like bullet proof glass and windscreens?
Roads where you get snow aren't generally located around deserts. Well, most roads aren't around deserts. In the UK for example, plenty of roads, no deserts.
Because snow is white and reflects the suns energy. By converting to electric and heating under the snow, it acts in the same way as the elements in your car windscreen.
Nothing about PM or free energy here.
The article was probably written by some guy who knows nothing about these kind of devices and also at reasonable level for the layman. It says nothing about the operation tempreture but I don't think it is reasonable to assume they haven't tested it out.
Sure they are probably going to be problems but at this moment not much has been said about the complete workings of this "device".
One of the problem I can think of is that installing and building this thing would be very complicated. They would like have to build it on scene and take the road out of commission for a reasonable time.
However, I don't think that is enough to label it a stupid idea as OP stated.
Article said:
The heating elements would work "like in the rear window of your car," said the inventor, who intends to experiment with temperature settings during the next stages of the development process.
"would work" implies they haven't built it, only created the concept. We know the concept works because of car windscreens.
"intends to experiment..." implies they aren't entirely sure what temperatures are required for use / are available.
Because it's only a concept in someone's head by the look of it.
It causes chaos when asphalt roads are out of commission for minor works.
I certainly wouldn't call it stupid, but I don't think it's the most thought out idea I've seen recently.
If the snow reflects it, then how will the solar cells, which are UNDER THE SNOW, going to capture it?
Logic fail.
And the energy thing is dumber than the hamster-well generation idea. If you're not in a desert, then a coal power plant will give you the same energy for 1/1000000000000000000 of the cost.
I didn't complete the reading because not all the text was displayedon my mobile device. :'( Thanks for clarifying that.
Logic fail.
I pointed this particular issue out earlier. But you said "If there is enough energy from the sun to melt the snow, why doesn't the sun melt it directly?" - my response was why the sun wouldn't simply melt the snow and how the system could (if given the same energy - solar to electric to heat).
What? Where are you pulling your figures from? You do realize you don't need to be in a desert for solar. Heck you can heat your water from solar in the UK quite efficiently most of the year.
Logic fail.
You realize that it doesn't snow all day in the winter and also the summer, right ? Hence, some energy could be stored.
I am not saying this is how things are but from my experience is usually snows overnight and that is usually when most of the accumulation takes place. When it snows during the day, cars usually do a good job of keeping the road nice and slushy due to the friction between the road and tires.
However, charging such a big device when cars are constantly blocking it's energy source is a problem.
Logic fail.
you don't care if it's got snow on it, because you hook it up to the grid. what else are you going to do with all that power the rest of the year?
putting heat tracing in a roadway sounds easy enough. the rest of it sounds like a materials engineering nightmare that would cost a fortune and be unreliable.
Curl, want to hear a really dumb idea?
I propose a heavy, giant metal tube that will not only fly through the air, but safely carry hundreds of human passengers AND their belongings!
Completely nuts, right?
How is a solar powered flashlight dumb?
Yes, but if you put wings on it, it'll work great!
They stole my idea!:mad: :rolleyes: :-p :biggrin:
They could use solar paint and just paint it right on the road...
When this idea fails, the next guy will propose to build a special low-cost roofing over all the roads. He will say that the roof will keep the sun, snow and rain off of normal roadway allowing it to last much longer. He will remind everyone that the cost of the roof is cheaper than the previously proposed rip-up of normal road and laying of solar cell roadway, and the risk is lower because roofs are standard and proven technology, barring a few minor accidental cases of snow-collapsed roofed buildings.
OK, which government agency do I submit my proposal too? :smile:
It's not if it includes some method of storing the energy.
What cracks me up the hardest is that this fool thinks he found an ingenious place to put his solar cells, as if the Earth is running out of surface for them.
Also its funny how ignorant people are about solar cells, they think they exist therefore we can cover up an ocean with them, as if they're made of dirt. Even if the industry can crank out solar polymers faster than humans crank out feces, it wouldn't be enough to do jack.
The important thing to remember when considering this design, is that the road doesn't have to be heated all the time. Only when there is snow/ice on it. As long as there is some mechanism of storing the energy (or depositing and withdrawing energy from the grid), this seems to me like it should work. Basically the whole time the sun is shining, you collect the energy, then when it snows, you heat the road only long enough to clear it. It seems to me that, given the high albedo of snow, and the (relative) efficiency of collecting energy with solar panels, this should be fairly straightforward technology to design and implement. Modern glasses are more than strong enough for the job, and as long as the roads are built in segments (with flex/break lines), and maintained, there shouldn't be a significant problem with wear. Perhaps sections could even be designed to be easy to lift, allowing for easier laying of utilities/pipes/whatever under the road if needed.
Whether this would be more or less economically viable than just installing a bunch of solar panels in the middle of nowhere and hooking them up to the grid, and installing conventional heated roads is up for debate (and/or more economical than clearing the snow with conventional snow removal methods). If his proof of concept/prototype works out, then the next logical step would be a cost/benefit analysis comparing this to existing methods of snow removal, including all maintenance costs associated with each technology.
Where it snows, all roads should be Teflon coated and tilted 15 degrees to the right or left. The snow just slides off.
Cars too?
NeoDevin said:
Cars too?
I'm working on that little problem.
What if tires were made of cheese wheels? Nothing seems to stick better to a Teflon skillet than cheese.
So would the cars, but hey, if the snow is the only thing you're concerned about, it's a winner.
Can't here, even though we get quite a lot of sun here in Colorado. I designed the cheapest possible solar water heater (less than 1/4 the cost of commercial units for the same output), and the payback period was still more than 10 years. I made more financial sense to keep paying for natural gas while investing the funds in the S&P 500, so it was a no-go.
One thing I've long since learned about most writers in popular media is that they're writers, not scientists.
I live in a South Wales valley (famous for rain and more rain)...
Anyhow, the council have recently gone mad installing solar panels and solar heating systems on the houses. From what I've seen of them, they give a fairly good (so far as solar goes) output - particularly the electric side of things which did show a reduction in electric bills.
I'm not going to sit here and tell you they're fantastic and work all year round because that's BS and my own preference is against them. However, for 6 to 9 months of the year they do give quite a good saving in bills.
Dumbest idea I've even heard in my life...
Sounds to me like you've lived a short life so far. What about f = ma? Einstein's still chuckling about that one and he's been dead for half a century.
I haven't seen the link in the OP but it seems like it proposed multiple ideas related to:
1. Road construction materials
2. Solar energy capture
3. De-glaciating roads through heating
AFAIK, 3 is the "heated runway" technology currently used in airports, being applied to roads.
Re 1, glass beads mixed with asphalt are already being used in paving.
  • #31
Maybe they should have thought about the snow problem before they built a city in a place where it snows so much.
The idea is just so stupid. It's one of the most impractical ideas I've ever heard. How many roads would they cover? Just one, or all the roads in the city? Is snow really that bad that you need to change out all the roads in a city for it? Why not just make the cars better able to drive through it?
And I'd also love to see how good your traction is on wet glass.
  • #32
bolding mine
Actually, they're made of sand.
I like the idea of heated roadways, and considered this a few years back. I work on a fairly steep hill and have witnessed 6 buses jack-knifed trying to go down the aforementioned hill. Melting the ice and snow from at least the steep sections would not be that expensive.
  • #33
How about salt sprinklers in dangerous spots, like curves and hills?
  • #34
nah that's too simple.
we need a 4 million dollar, alien-tech bulletproof flexglass roadway with 17 layers of nano-tech UHMW synthetic polymer optical grids and computer chips to do the same job done by petroleum waste and salt.
  • #35
what we need is research to build carbon decatubes that we could drive inside of
  • #36
You know, Russ, I really wanted to do that with my Acura Integra a few years back! Now I want to do it with my truck.
The problem is, light aircraft aren't designed for highway crash safety. Those extra pounds which keep us safe on the highway exact a huge toll on getting the dang vehicle into the air. Yes, it can be done, but my 1991 Acura Integra, with 120 HP would have been huffing and puffing through just about any flight, although it breezed it's way at 120 mph throughout the autobahns of Germany. Similarly, my truck sips less gas per mile at 90 mph than it does at 60, probably because of the tailgate. Still, I computed that if I turned into an aircraft, it would have to be a powered glider, at best. Yes, I could make California at about 100 mph, but using more gas than I'd have used if I'd driven, and at a total cost of 3 times what it takes me to drive to Denver, catch a commercial flight to Sacramento, rent a car to Merced, and back a week later.
Life is grand. Commercial air transportation is a freaking miracle.
  • #37
Wouldn't you get horrible traction driving on glass?
  • #38
you could have a rough surface, like sand or concrete. speaking of concrete highways, they do last a long time. but i think the traction and wear on tires is supposed to be worse.
  • #39
Would full-spectrum solar cells be a difference in cloudy weather? Those are on the way.
  • #40
Here's a thought: Incorporate carbon black in the asphalt roadway to absorb nearly all light.
http://en.wikipedia.org/wiki/Carbon_black" ...
Ok, then how about incorporating very finely shredded rubber tires in the concrete used for roads? Probably too much give. Perhaps incorporating carbon black in concrete might work, but it would take a lot of carbon black. Expensive.
Most asphalt roadways only contain about 5% asphalt, with the remainder being aggregate of stones, sand, and gravel. http://en.wikipedia.org/wiki/Asphalt#Rolled_asphalt_concrete" It's still black, however, absorbs most sunlight which reaches it, and around here (Colorado Springs) those roadways are the first to melt the snow.
This idea linked in the OP really is one of the dumbest ideas I've ever heard.
  • #41
Here are some estimates. I don't intend to defend them so if you have different estimates, just post them. If there are mistakes in my math, please correct them.
1. 10 inches of snow is equivalent to 1 inch of rain.
2. It is not unusual for snow to fall at the rate of 1 inch per hour.
3. 1 inch of snow per hour on a square meter of road is 2.54 * 10^4 g/hr
4. Heat of fusion to turn ice to water is 334 joules/g
5. Heat to melt one hour's worth of snow falling on 1 m^2 is 334 * 2.54 * 10^4 joules = 8.48 * 10^6 joules
6. Heat of sunlight is 600 watts/m^2
7. 600 watts for 1 hour is 2.16 * 10^6 joules
Unless my assumptions and/or calculations are wrong, this idea won't work.
  • #42
Whew...for the price of some of these ideas, it would be more cost effective to just put a roof over the road.
  • #43
You are assuming that snow falls at an average rate of 1 inch per hour, and/or that no energy can be stored during times of less snowfall.
While 1 inch per hour may not be uncommon, I sincerely doubt anywhere gets 1 inch per hour averaged over the entire winter (assuming winter lasts 3 months, that's ~185 feet of snow, imagine shoveling that!). If energy can be stored (as I believe was proposed in the article) when it's not snowing, and the road heated only while/after it snows, then you'll find that your energy calculation depends on the average rate of snow fall, rather than the maximum.
  • #44
  • #45
That... is not a bad idea...
  • #46
And then we could put solar panels on the roof!
  • #47
And then drive on the roof too!
  • #48
And... we're back to square one...
  • #49
Grr... you're right. Maybe they could just put a roof on it.
  • #50
Wow Curl, your attitude stinks. I am not convinced of this idea myself either, I thinks its a lot of aggro to go through, when you can just use a plough. Who are you to call people retarded, with the dumbest idea ever, and so on? So many inventors in history have been considered retarded, crazy, or even heretics. What have you invented lately?
