Dynamic FBD - Man and box sliding on an incline
The discussion focuses on analyzing the dynamics of a man and a box sliding down an incline, emphasizing the forces acting on both objects. The user initially assumes both will slide down but later realizes the box accelerates faster than the man, indicating a tension in the rope connecting them. They explore the role of static friction and the maximum pulling force the man can exert before slipping occurs. A hint from a teaching assistant suggests treating the system as one, leading to confusion about the correct free body diagram (FBD) representation. Ultimately, the user seeks clarification on the FBD and the relationship between the forces acting on both the man and the box.
theBEAST
http://img59.imageshack.us/img59/493/capturemml.png
Here is my attempt. I assumed that both the man and the box would slide down the incline. (The box is the left diagram and the man is on the right)
http://img35.imageshack.us/img35/7628/photorxq.jpg
The acceleration I get from this attempt tells me that they accelerate the other way. So do I have to change the directions of the friction forces to find the answer? I am not sure what to do next. Also how do I use the coefficient of static friction in this question?
First find the maximum force can be applied(or pulled) by the man before he slips.
Is that just 784sin(37)? Since it's limited only by the friction force.
2 objects, man and box.
3 forces acting on the man.
The components of his weight, the force he pulls the box and static frictional force-Nμs.
Pulling force is limited by static force.
Check if his pulling force greater than the net downward force acting on the box.
Okay so I was given a hint by TA to assume there is no rope and to find the accelerations of both the box and the man. Turns out, the acceleration of the box is greater than the man so they will accelerate down the slope as one system and there will be tension in the rope.
As for what you said about the pulling force, do you mean the tension in the rope? I am confused :S
Next I proceeded to solve the system of equations but I still get the wrong answer:
http://img18.imageshack.us/img18/408/photo1feh.jpg
Just imagine there is a spring in the middle connected between the man and the box.
If the spring is contracted, it will pull the man down and the box up.
The spring is the muscles of the hands that being contracted to produce the force.
From the question, the man is trying to pull.
So he is applying a force and is transmitted to the box via the rope.
This force must be equal and opposite, according to Newton's 3rd law.
I'm not quite sure how to redraw the FBD with the muscles. Is my FBD correct first of all?
a=g(Sinθ-Cosθμ)
Since kinetic friction for the man less than the box, the rope will not be taut.
Thus the box will accelerate independently.
