E-B crossed fields parallel plate
unscientific
A parallel plate has p.d. V with one end 0V and the other +V. B-field of strength B has direction along plates. An electron is released from rest at 0V plate. Show that if V is less than e(DB)2/(2m) the electron will not reach the other plate.
At half-way inbetween the plates, the radius must be d/2
R = mv/Bq
d/2 = m*√(2*e*0.5V/m) / (Bq)
I end up with e(DB)2/(4m) instead..
Hello.
I don't follow your statement. Could you just as well reason that when the electron is 3/4 of the way across, then the radius must be d/4? If so, would you get the same answer?
I think you're going to need to set up the equations of motion for the x and y components of acceleration.
TSny said:
Hello.
define x as upwards, y into the plate.
max = eV/d
may = qvB
x2 + y2 = d2
is that right?
Let me make sure I understand your choice of directions and signs. Correct me if I'm wrong. You're choosing the electric field in the negative x direction so that the E field accelerates the electron in the positive x direction. The x-axis is oriented perpendicular to the plates.
y-axis is parallel to the plates and B is parallel to the plates but perpendicular to both the x-axis and the y-axis such that when the electron starts moving the B field begins to deflect the electron toward positive y.
But once the electron is deflected some in the y-direction by the B field, the electron will then have a y-component of velocity. So, the magnetic field will then cause some force parallel to the x-axis! So, you need to include a magnetic force term in your equation for ax.
The electron is going to move along a curved path, so you can't say x2+y2 = d2 (if d represents the separation of the plates).
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
