How to Calculate the E Field Inside a Charged Cylinder?
  • Thread starter Thread starter cragar
    Cylinder Field
To calculate the electric field inside an infinite charged cylinder, Gauss's law is applied, leveraging the symmetry of the cylinder. The charge enclosed within a Gaussian surface is determined by the ratio of the areas based on the cylinder's radii. The relationship for charge Q is proposed as Q = (Tr^2)/R^2, assuming a hollow cylinder structure. The discussion emphasizes that total charge is not necessary for determining the electric field in this scenario. Understanding these principles is crucial for accurate calculations of electric fields in charged cylindrical geometries.
cragar
This is not a homework problem. Let's say I have an infinite charged cylinder with radius R .
And I want to find the E field inside the cylinder. If the cylinder has a line charge of T, that is charge per length. would the charge enclosed just be the ration of the areas of the smaller radius to the larger fixed radius of the cylinder.
would Q equal \frac{Tr^2}{R^2}
As you have a "smaller radius" and a "larger radius", I think you mean a hollow cylinder, similar to this?
To find the electric field inside, you can use the symmetry of the problem and Gauss's law, you do not need any total charge to do that.
Which charge, where?
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
