Easy change in direction question
  • Thread starter Thread starter rcmango
    Change Direction
The discussion centers on understanding the concept of change in velocity when an object changes direction. A plane traveling north at 200 m/s and then south at 200 m/s results in a total change in velocity of 400 m/s south, as the velocities are in opposite directions. The confusion arises from the difference between velocity and speed, and how direction affects the calculation of change in velocity. Examples provided illustrate that when switching directions, the velocities are added algebraically, leading to a greater change. The key takeaway is that when an object reverses direction, the change in velocity is the sum of the speeds in opposite directions.
rcmango
if there's a plane traveling north at 200 m/s and then travel south at 200 m/s then its change in velocity is 400 m/s south.
okay so the answer is 400 m/s south.
however, i don't understand why the change is 400, and not 0 or just 200?
i see the new direction is south.
is there an equation for problems like these?
maybe you could make up another example with the answer included so i can see this better.
thanks.
Think about it... let's say your traveling 60 miles per hour and then all of the sudden your traveling 20 miles per hour in the same direction? What's the change in velocity? Well, that is 40 miles per hour.
If you're going 60 miles per hour and then you stop all of the sudden, what's the change in velocity?
Now, if you're going 60 miles per hour and then you start going 20 miles per hour in the OPPOSITE direction, what's the CHANGE in velocity?
...then i would say it is 60 miles per hour, since your not moving anymore. correct?
also,
...i would say 80 miles per hour in the opposite direction because you add them together it seems?
this all seems confusing to me.
