Eclipsing binary stars question
  • Thread starter Thread starter warfreak131
    Binary Stars
The discussion revolves around calculating the flux ratios of an eclipsing binary star system with two stars of differing temperatures and sizes. Star 1 has a surface temperature of 5000 K and is larger, while Star 2 has a temperature of 10000 K and a radius four times smaller. The challenge lies in computing the flux ratios fa/fnormal and fb/fnormal, considering that the light from one star is blocked when the other passes in front. Participants express confusion over whether to use flux or brightness for these calculations, as the question focuses on flux without mentioning brightness. The conversation highlights the need for clarity in the problem statement regarding how to account for the light obstruction during eclipses.
warfreak131
Figure 1 showed the light curve for an exlipsing binary system. This system consists of 2 stars. Star is is the larrger of the stars, and has a surface temp of T1=5000 K. Star 2 has a surface temp of T2=10000K. The ratio of their radii is R1/R2=4. Fnormal is the flux from the system when neither star is blocked. and fa and fb are the fluxes when star 2 passes in front of, or behind star 1, as seen from Earth.
(A)Compute fa/fnormal
(B)Compute fb/fnormal
The light curve looks like this:
http://www.ifa.hawaii.edu/users/mendez/ASTRO110LAB07/modeleb.gif
where the top line is fnormal, the drop at x=.5 is fa, and the drop at x=1 is fb.
Flux = {\sigma}T^{4}
Brightness = {\pi}R^{2}{\sigma}T^{4}
I am being thrown off because the question says compare the fluxes, but just computing the flux doesn't take into account the fact that you are blocking out some light from each star when one passes in front of another. For that I would use brightness, but he makes no mention of using brightness in the question.
sorry, i didnt post this in the astronomy section
