Edison's Electric Companies: Understanding DC Processes
  • Thread starter Thread starter vectordog
    Dc Electric
Edison produced direct current (DC) electricity using series wound dynamos, which were driven by coal-fired steam engines. These dynamos, referred to as "self exiting," generated electricity through the residual magnetism in their iron components without the need for external permanent magnets. The current produced was fed through field coils, enhancing the magnetic field and increasing the current output. Edison's approach contrasted with Tesla and Westinghouse, who focused on alternating current (AC) for long-distance power transmission and pioneered hydroelectric systems. This discussion highlights the foundational differences in early electrical generation methods.
vectordog
Can anyone describe for me the process that edison originally used to produce DC when he built his original electric companies?
There was a commutator on his generator's armature.
Your question is peculiar. He didn't use a "process". He generated electricity with a device. His generators were series wound DC generators referred to as "dynamos" at the time. The dynamos were driven by coal-fired steam engines. He manufactured all his dynamos himself and often tinkered with the engineering of them.
Series wound dynamos are 'self exiting', meaning, there are no external permanent magnets used. Simply turning the rotor causes electricity to be generated from the small residual magnetism in the iron components. This current is fed through the field coils on its way out of the system which increases the strength of the magnetic field which, in turn, increases the strength of the current generated. It levels off for any given speed of rotation, of course.
Coal fired steam engines was what I was wondering. Thanks. My class was watching a video on Tesla, and we were just curious.
Tesla/Westinghouse differed not only in adopting AC for long distance transmission of power but also in being pioneers of hydroelectric systems.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
