How Does Changing Coordinates Affect the Momentum Space Wavefunction?
  • Thread starter Thread starter ehrenfest
    Change Coordinates
ehrenfest
For a wavefunction given by
\psi(x,t) = \sum a_n u_n(x) exp(-i E_n T/\hbar) how would you show that a change of coordinates x > x + d does not affect the momentum space wavefunction phi(x) by more than a phase change?
You get phi(x) by Fourier transforming psi.
So, I do not see why it would affect psi at all because you are moving the origin d to the left but you are integrating over all pace in the Fourier transform.
You mean we get phi(p) when doing Fourier transformation with respect to p. How is E related to p? Have you tried doing the mathematics or are you just trying to solve it by looking at it? =P
What you are saying exactly is not clear. Do you want to show that for two functions (of 'x') f and g and their Fourier transforms (functions of 'p') F and G, if f and g obey
<br /> g(x)=f(x+a)<br />
then F and G obey
<br /> G(p)=e^{ipa}F(p)\;.<br />
Is this what you want to show?
then F and G obey
Exactly! That F and G only differ by a phase factor (so their moduli squared are the same).
<br /> \phi(p,t) <br /> = \int\psi(x+d,t) e^{-i p x/ \hbar}dx <br /> = \int\psi(u,t) e^{-i p (u - d)/ \hbar}du<br /> =e^{i p d/ \hbar} \int\psi(u,t) e^{-i p u/ \hbar}du
I think that rephrasing of the question helped me finish it!
I'm glad. Good luck w/ the rest of your work.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
