Elastic and isotropic constitutive relationship
The discussion focuses on the necessity of including an indeterminate hydrostatic term in the stress tensor for incompressible materials, both solids and fluids. Incompressibility implies that hydrostatic stress does not result in strain, making it impossible to derive it from the strain tensor. Despite this, hydrostatic stress is essential as it effectively transmits loads within the material. Participants clarify that hydrostatic pressure represents mean normal stress, which cannot be disregarded in Hooke's law under indeterminate conditions. Understanding this relationship is crucial for accurate modeling of material behavior.
ftarak
Hi everybody,
I have just a question about elastic and isotropic constitutive relationship
Why does the stress tensor need an indeterminate hydrostatic term for an incompressible material? for both solids and fluids.
"Incompressible" means that if you have a hydrostatic stress (or a constant pressure, which is the same thing), the strain is zero.
So you can't get the hydrostatic stress by multiplying the strain tensor by something.
But it is a phsyically real stress, that transmits loads through the solid or fluid, so you have to include it in the model some other way.
thank you for your answer. that was helpful. I got the point, the point is that the hydrostatic pressure is mean normal stress. and we cannot cancel out the hydrostatic term in the Hooke's law in the situation, which is indeterminate.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
