Elastic Potential Energy and Energy Exchange
A 3 kg ball dropped from 0.8 m compresses a spring with a constant of 1200 N/m, leading to a maximum compression of 0.22 m. The relevant equations include spring potential energy, gravitational potential energy, and kinetic energy. Initial confusion arose regarding the height reference point for calculating gravitational energy, but the issue was resolved. The correct approach involves considering the gravitational energy as directed downwards towards the ball. The discussion highlights the importance of accurately defining reference points in energy calculations.
Vegeance
A 3 kg ball is dropped from a height of 0.8 m above the top of the spring onto a vertical coiled spring sitting on the floor. The spring constant of the spring is 1200 N/m. Determine the maximum compression of the spring as the ball comes momentarily to rest before rising again. (0.22 m)
1/2kx^2 (Spring Potential Energy as the area of kx graph)
Epg=mgh (Gravitational Potential Energy)
1/2mv^2 (Sum of energy -> Average kinetic energy of all particles -> velocity)
I am not sure where I went wrong.
I meant b=-29.43.
x = 0.04905m
Decide from where do you count the height of the ball. If it is the upper end of the spring in equilibrium, then the final height is h2=x2 (a negative quantity).
ehild
Nevermind, I figured it out. It makes more sense for the gravitational energy h2 to be down upwards to the ball.
The first statement I made was false.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
