Electric charge and potential energy
The discussion revolves around the potential energy of a charged particle in an electric field, specifically comparing different expressions for potential energy related to electric charge and potential difference. Participants are examining the relationship between force, electric field strength, and potential energy in the context of point charges and uniform electric fields.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the differences between potential energy expressions U = Eqd and U = Vq, questioning when to use each. There is discussion about the implications of uniform versus non-uniform electric fields and how these affect potential energy calculations.
Some participants have provided clarifications regarding the validity of the equations and the conditions under which they apply. There is an ongoing exploration of the concepts without a clear consensus on the implications of the different expressions for potential energy.
Participants are considering the implications of moving charges from various distances and the nature of electric fields produced by point charges versus uniform fields. There is mention of homework constraints and the need for precise problem statements to facilitate further discussion.
brake4country
A particle with charge q experiences a force F when placed a distance d from a point charge. At a distance d, the electric field has a strength E and a potential V. Which of the following represents the potential energy of the charge?
(A) Fd
(B) Eqd
(C) Vq
(D) Ed
U=Eqd; U=kq1q2/r; V = Ed; V = kq1/r.
I chose B but the correct answer is C. We know that the potential energy of a charge in an electric field is the force times the displacement: U = Eqd. What is the difference between answer choice B and C? Thanks in advance and if I didn't provide enough explanation for my question, please let me know.
The voltage has units of Volt or, what we are interested in is Joule per Coulomb so V.q has units of Joule, which can be energy, but also B) proposes a result with unit of Joules, so what's the difference ?
Well, The ELECTRIC potential energy is a potential energy, it just depends on you distance to the source of electric field and by displacing the charge as B) proposes, you increase it's PE, or give it any form of energy, what I mean if d = r (the distance btw the charge) then B) would be true and in either case C) is the most general and the right one, Hope I've made it a little bit clearer and good luck .
Right. When I look at the units for B and C, I notice they are both in Nm = J. However, can you clarify when to use U = Eqd and U = Vq? My book states that Eqd is the potential energy or work done, which makes sense but I cannot see how they get U =Vq. Thank you.
The equation U = Vq is valid in general. The expression Eqd is used for the case of a charge q in a uniform electric field. Usually one writes ΔU = -Eqd where d is the distance the charge q moves parallel to the uniform field and ΔU is the change in potential energy of the charge.
Ok. I also noticed that Vq = (J/C)(C), which is just Joules. I understand this by process of elimination. I wonder, did the problem imply a "uniform electric field" in this case? How would I know when the electric field is uniform or not?
A point charges produce a field that gets weaker as you move farther from the charge. So, the electric field is not uniform.
When you have two point charges, you can think of one of the charges as placed in the field of the other charge.
A uniform field is a special situation. It can be thought of as produced by a large flat plate of uniform charge density. Or,it can be produced by two large, flat parallel plates of opposite charge.
brake4country said:
Right. When I look at the units for B an C, I notice they are both in Nm = J. However, can you clarify when to use U = Eqd and U = Vq? My book states that Eqd is the potential energy or work done, which makes sense but I cannot see how they get U =Vq. Thank you.
Eqd can be visualised as the change in potential, asas TSny said above ΔU =- Eqd, because d isn't necessary the distance btw the charges whereas the potential directly depend on that distance r and if you have noticed Vq = E*q*r that all about it !
Oh I see. I have a similar problem which states the same scenario but the charged particle is moved "from a great distance". In this situation, it would be appropriate to use Eqd, right?
Edq is work, it's not allways a potential energy, doing work on a charge from a great distance give it enough kinetic energy to leave the field, E changes by the distance btw the charges, suppose that you're in a gravitation field, the work you do on a mass W = mgd isn't allways equal to the potential U = mgh,
Imagine that you lift the mass from a 10 meter roof a 5 m upward, this case W = 5mg whereas U = 15mg, that's the difference btw Eqd and Vq, V = E*r it's like gh, just focuse on these, Vq is the potential and Eqd is work, it may not be potential !
That is so very helpful! Thank you for your help!
If will help if you state the problem exactly as given.
well basically, voltage(potential difference) is equals to work done per unit charge. That means the amount of work done required to move a charge from one point to another point. That why it is called potential DIFFERENCE . To make things easier, there's an equation where V = W/Q.
So, if you want to find the potential energy of the charge. Use this formula to get the answer ^_^
Thank you. I will post this question in another thread.
  • · Replies 22 ·
11K
  • · Replies 23 ·
