Electric charge on conductors , capacitors
The discussion centers on why charge resides on capacitor plates rather than on closely placed wires or circuit traces, highlighting that the attraction between opposite charges and the distance between them allows for charge retention in capacitors. It questions whether charge accumulation is influenced by conductor geometry or spacing, suggesting that two wires with the same surface area and gap as capacitor plates would not have the same capacitance. Participants note that while wires can accumulate small charges, these are often negligible compared to capacitors. A concept is proposed for a capacitor that would quickly lose its charge after disconnecting the voltage source, though this would result in a poor capacitor design. The conversation emphasizes the complexities of charge behavior in different conductor configurations.
Crazymechanic
Hi I'm wondering why does the charge resides on the plates on a capacitor when it's charged but not on say two closely placed wires or circuit traces etc, well I do understand that charges stay on capacitor plates because the opposite charges tend to attract and with a distance between them they stay as close as possible for as long as possible.
So the question is more like , given the same amount of voltage does the charge accumulation depends on the conductor geometry or spacing between them ?
Say I have a parallel plate capacitor and two wires with the surface area the same as that of the plates , and the gap between each of the wires just as big as that of the plates will they ahve the same capacitance or no?
P.S. although I think it's impossible but would it be possible to make a capacitor which looses it's charge right after the source or the supply is taken away , well it wouldn't be a capacitor anymore but still , say I needed a device with which I can use + charge to attract some negative charge on the other plate but let it go just as when I disconnect the positive charge ?
As upon disconnecting a capacitor it would discharge slowly.
the 2 "parallel wires of a circuit will have a charge on the for as long as there's a voltage applied
Remove the voltage and the charge will dissipate out into the attached circuitry
yes of course it is possible ... you just make a capacitor that has a very leaky dielectric between the plates so that current (charge) flows between the plates and balances out.
This of course would be a VERY poor capacitor
Dave
Two wires laying next to each other will have a small but non-vanishing capacitance that indeed depends on the exact geometry of the wires such as their sizes and distances. That means that small but non-vanishing charges might indeed build up in those wires. For most purposes these charges can be considered negligible (but not always). Excellent question.
@davenn , well yes a poor capacitor would do , but the problem is I need a good isolation between the plate so no current (in theory) runs between them but so that when I switch the negative potential off of one of the plates the + doesn't linger on the other as it would normally do.
The purpose is so that I could switch a negative potential on the legs of two capacitors in series so that i could get charges to run back and forth between them.
The thing is with a normal capacitor I can't do that just because the cap needs to be discharged or drained to ground for it to reverse polarity.
@dauto , why would that be an excellent question , just asking ? :)
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
