Where Is the Electric Field Zero Between Two Charges?
  • Thread starter Thread starter phy43
    Charges Electric
The discussion focuses on determining the point between two positive charges where the electric field is zero. A 6μC charge is located at (0,0) and a 1μC charge at (0,1m). The electric fields from each charge must be calculated and set equal to each other to find the point of zero net electric field. The equations for the electric fields from both charges are derived, leading to the conclusion that the net electric field can be expressed as E_net = (54 + 9)/r^2. The problem is resolved by recognizing the need to express distances in terms of a variable and considering the directions of the fields.
phy43
a 6uC + charge is at (0,0) and a 1uC + charge is at (0,1m). Where between them is the electric field equal to 0?
F=qE
F=K(q_1)(q_2)/r^2
F=K(q_1)(q_2)/r^2
F=(9.0*10^9)(1*10^-6)(6*10^-6)/(1^2)
F=5.4*10^-5 (The force each exerts upon each other)
F=qE
Since E=0, F=0
F=0 at:
0=K(q_1)(q_2)/r^2
Find r
0=(9.0*10^9)(1*10^-6)(6*10^-6)/r^2
And this is where we have a problem
You want to study the field from the two charges at various points, not the force between the two charges. Write an expression for the field at point X from each charge. Add to get the total field. (Careful with signs.)
Electric field at distance r for each charge
E=Kq/r^2
E_1=(9.0*10^9)(6*10^-9)/r^2
E_1 = 54/r^2
E_2=(9.0*10^9)(1*10^-9)/r^2
E_2 = 9/r^2
E_net = E_1+E_2 = 54/r^2 + 9/r^2
E_net = (54+9)(1/r^2)
E_net = 63/r^2
0 = 63/r^2
E=Kq/r^2
If a point is a distance X from charge #1, how far is it from charge #2?
E_1 = 54/r^2
Instead of calling the distance r, call it X. Don't plug in numbers right away. (And μC = 10^-6, not 10^-9.)
What direction is the field?
E_2 = 9/r^2
Instead of r, write the distance in terms of X and the distance between the charges.
Note that different directions will get different signs.
Thanks, figured it out.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
