How Is the Electric Field Around an Infinitely Long Wire Derived?
The electric field around an infinitely long wire with uniform charge distribution is derived using the formula E = (1/2πε₀)(λ/r), where λ is the linear charge density expressed as λ = dq/dl. To derive this, one starts with the general electric field equation E = (1/4πε₀)∫(ρ/r²)âdV, adapting it for a wire by substituting volume with linear charge. The integration is performed from negative to positive infinity, focusing on the radial symmetry of the field. Resources and examples for this derivation can be found through online searches, including educational sites like HyperPhysics. Understanding this derivation is crucial for grasping electric fields in cylindrical symmetry.
Uku
I know that around an infinitely long wire with even charge distribution the electric field is expressed as:
E=\frac{1}{2\pi\epsilon_{0}}\frac{\lambda}{r} (1)
Where \lambda can be expressed as \lambda=\frac{dq}{dl}
Right, but I want to know where I get this formula from, I mean the E field.
So I know that in general:
E=\frac{1}{4\pi\epsilon_{0}}\int\frac{\rho}{r^{2}}\widehat{r}dV
In my case I don't have volume, I have a thread. I can also forget about the unit vector, since the field is radially pointed outward. The charge is evenly distributed so I can write:
E=\frac{1}{4\pi\epsilon_{0}}\lambda\int\frac{1}{r^{2}}dL
Okay, but now... I can integrate the expression from minus infinity to infinity, but how do I get to that formula (1)
You can find a number of sites that work this out for you. A google search, or even a search here at PF will give you many looks at this problem. Here is one, for example.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elelin.html
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
