Electric Field Calculation for Coaxial Plates with Holes
  • Thread starter Thread starter superkraken
    Electrostatics
The problem involves calculating the electric field through the axis of coaxial holes in two infinitely large plates with uniform surface charge densities. The setup includes two plates separated by a distance d, with round holes of radius R, and the task is to find the electric field as a function of distance l from the holes.
  • Participants discuss finding the electric field due to both plates and subtracting the field due to the holes. There are questions about the integration limits and the components of the electric field to consider, particularly focusing on the symmetry of the problem.
Some participants have provided guidance on how to approach the integration, suggesting that the integration can be simplified due to symmetry. There is an ongoing exploration of the necessary components and the setup for the integration.
Participants express confusion regarding the integration process and the specific limits to use, indicating a need for clarification on these points. The discussion reflects the complexity of the problem setup and the assumptions involved.
superkraken
two infinitely large plates are at a distance d from each other .they carry a unifor surface charge of densities X and -X.the plates have round coaxial holes of radius R.with d<<R.find the electric field through the axis of the holes(taking them as circles) as a function of distance l from them.[/B]
i think i should find the field due to both the plates and subtaract the field due to the hole.i don't exactly know how to do that if that's how it done.
Ok then. Show what you get for the field of the plates (without hole).
Then show what you get for the hole. Since you are on axis, you only need to consider one component of the field. What can you say about the direction of the field? Just do an integration over the surfaces of the holes, summing over the nonzero component.
ok but what do i integrate from where to where?if i take a small area of width dx and at a distance dr from tthe center .the answer is pretty confusing
Integrate over the surface area of the circle. Thanks to symmetry, you can do this as a 1D integral.
  • · Replies 58 ·
  • · Replies 16 ·
