Electric field, direction and magnitude
The discussion revolves around calculating the electric field due to a uniformly charged rod at a specific point. The user initially calculated the electric field magnitude as 6.17 * 10^5 N/C, while the correct answer is 1.59 * 10^6 N/C. A key point raised is the importance of considering the direction of the electric field as a vector, which may have been overlooked in the calculations. The user is advised to refer to textbooks for clarification on the electric field due to a wire and to ensure the correct interpretation of the axis of the rod. Accurate calculations require careful consideration of both magnitude and direction.
minifhncc
A rod 14.0 cm long is uniformly charged and has a total charge of -22.0μC. Determine
(a) the magnitude and
(b) direction of the electric field along the axis of the rod at a point 36.0 cm from its centre.
[I can do (b)]
Electric field at the point due to a small element, ΔE=(k Δq)/(x^2)
I got down to the total field at P being,
(kQ/l) * integral of 1/x^2 from x=0.29 and x=0.43
and I get 6.17 * 10^5 NC^-1
But the answer says 1.59 * 10^6 NC^-1
Are the answers wrong?
The given answer is right, how did you get that wrong value?
ehild
= 8.9876* 10^9 * -22 * 10^-6 / 0.14 ... etc
And what is in place of etc?
ehild
I don't think you have considered the direction of E.
E is a vector, and you need to treat the two components separately.
Check any book for the field due to a wire, and you'll understand what you've missed.
It depends what is meant on "axis of the rod". It should be the straight line along the rod.
ehild
