Electric field direction on a grounded conducting sphere
4 replies · 2K views
zapman345
Is the angle that the electric field makes on the surface of a grounded conducting sphere near a (positive) point charge 90°? I.e. is the electric field pointed radially outward from the sphere.
##E=-\nabla V##
I am required to find the direction of the electric field on the surface of a grounded conducting sphere in the proximity of a point charge ##+q##. The distance between the center of the sphere and the point charge is ##d## and using the method of images we find that the charge of the sphere is ##q' = -\frac{R}{d}q## then we can calculate the potential which I found here:
$$V\left(\vec{r}\right) =\frac{q}{4\pi\epsilon_{0}}\left[\frac{1}{\sqrt{d^{2}+r^{2}-2dr\cos\left(\theta\right)}}-\frac{\frac{R}{d}}{\sqrt{\left(\frac{R^{2}}{d}\right)^{2}+r^{2}-2\left(\frac{R^{2}}{d}\right)r\cos\left(\theta\right)}}\right]$$
Now we also know that the electric field is:
\begin{align*}
E & =-\nabla V\\
& =-\left(\frac{\partial V}{\partial r}\hat{r}+\frac{1}{r}\frac{\partial V}{\partial\theta}\hat{\theta}+\frac{1}{r\sin\left(\theta\right)}\frac{\partial V}{\partial\phi}\hat{\phi}\right)\\
& =-\left(\frac{\partial V}{\partial r}\hat{r}+\frac{1}{r}\frac{\partial V}{\partial\theta}\hat{\theta}\right)\\
\end{align*}
Can I from this positively say that the electric field outside the sphere is not radially pointed outward only, and thus does not make a 90° angle with the surface of the sphere?
I did but that wouldn't make the ##\theta## component vanish cause I find that $$E_{\theta} = -\frac{1}{r}\cdot\left(\frac{rR^{3}\sin(\theta)}{d^{2}\left(\frac{R^{4}}{d^{2}}-\frac{2rR^{2}\cos(\theta)}{d}+r^{2}\right)^{3/2}}-\frac{dr\sin(\theta)}{\left(d^{2}-2dr\cos(\theta)+r^{2}\right)^{3/2}}\right)\hat{\theta}$$ Which even at ##r=R## doesn't vanish, it does vanish for ##\theta=0## but that is a trivial solution as that is the line directly between the real and fictive charge used in the method of images. For any ##\theta\neq0## this won't vanish but intuitively I think it should vanish because we're talking about a spherical object.
Consider the case R →∞ , you should recover the flat plane case for the potential. I think you need to worry about the angle for the image charge...you seem have a sign wrong.
You were right. The potential I had calculated should be $$
\begin{align*}
V\left(\vec{r}\right) & =\frac{q}{4\pi\epsilon_{0}}\left[\frac{1}{\sqrt{r^{2}+d^{2}-2dr\cos\left(\theta\right)}}-\frac{1}{\sqrt{R^{2}+\left(\frac{rd}{R}\right)^{2}-2dr\cos\left(\theta\right)}}\right]\\
\end{align*}$$
Then for the electric field you will find $$\begin{align*}
E & =-\frac{q}{4\pi\epsilon_{0}}\left\{ \left(\frac{2\left(\frac{d}{R}\right)^{2}r-2d\cos(\theta)}{2\left(R^{2}+\left(\frac{dr}{R}\right)^{2}-2ar\cos(\theta)\right)^{3/2}}+\frac{2r-2d\cos(\theta)}{2\left(r^{2}+d^{2}-2dr\cos(\theta)\right)^{3/2}}\right)\hat{r}+\frac{1}{r}\cdot\left(\frac{dr\sin\left(\theta\right)}{\left(R^{2}+\left(\frac{rd}{R}\right)^{2}-2dr\cos\left(\theta\right)\right)^{3/2}}-\frac{dr\sin\left(\theta\right)}{\left(r^{2}+d^{2}-2dr\cos\left(\theta\right)\right)^{3/2}}\right)\hat{\theta}\right\}
\end{align*}$$
Which reduces to
\begin{align*}
E\left(r=R\right) & =-\frac{q}{4\pi\epsilon_{0}}\left(\frac{d^{2}-R^{2}}{R\left(R^{2}+d^{2}-2dR\cos(\theta)\right)^{3/2}}\hat{r}+0\hat{\theta}\right)\\
& =-\frac{q}{4\pi\epsilon_{0}}\left(\frac{d^{2}-R^{2}}{R\left(R^{2}+d^{2}-2dR\cos(\theta)\right)^{3/2}}\right)\hat{r}
\end{align*}
Pointing only in the radial direction on the surface as expected. Thank you for all your help.
