Electric Field due to a Charged Disk.
To find the electric field due to a charged disk with maximum charge at the center and decreasing towards the edges, one must first define the surface charge density as a function of the radial distance from the center. The discussion emphasizes the importance of showing attempts at solving the problem to receive assistance. It suggests starting with the surface charge density to formulate the electric field equations. The user is encouraged to explore the relationship between charge distribution and electric field strength along the axis of the disk. Understanding these concepts is crucial for solving the problem effectively.
phoibos323
Find the electric field due to a Charged Disk at a distance of "d" which is in the disk's axis direction. The charge has it's maximum value at disk's center and decreases towards the edges.
I have the solution for uniformly charged disk but I can't figured it out for the situation above. Thank you.
http://img78.imageshack.us/img78/2523/23735598xe1.jpg
http://g.imageshack.us/img78/23735598xe1.jpg/1/
Any answers?
What have you tried so far? No one would help you if you don't show any attempt. Start by writing the surface charge density of the disk in terms of r, the radial distance from the disk centre to any given point on the disk.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
