Electric field due to two point charge
8 replies · 65K views · last reply
Alexis565
Two point charges are placed on the x axis. The first charge, q1 = 8.00nC , is placed a distance 16.0 m from the origin along the positive x axis; the second charge, q2 = 6.0nC , is placed a distance 9.00m from the origin along the negative x axis.
Find the electric field at the origin, point O.
What is Eox, Eoy=?
Give the x and y components of the electric field as an ordered pair. Express your answer in Newtons per coulomb to three significant figures. Keep in mind that an x component that points to the right is positive and a y component that points upward is positive.
So here is what i did...
Using Coulombs equation to frind electric field E=kQ/r(sqrd)
I converted from nC to C and found E for both charges.
Then since they're asking for vector component. I plugged the number(E) into i^hat of both charges, and the j^hat is zero. Then i added it. But its saying that my answer is wrong. can somebody please help me.
What am i missing here? I am probably skipping the most important part of this problem...
They are looking for an answer like: (a, b)
Show exactly what you did and maybe we can spot the error.
I'm working on that EXACT same problem (we're probably working on the same masteringphysics assigment). This is what I got so far.
I start by "placing" a test charge at the origin.
Here's what I think I should do:
E = [tex]\frac{kQ_1}{r^2}[/tex] + [tex]\frac{kQ_2}{r^2}[/tex]
E_1 = [tex]\frac{(9x10^9)(8x10^-9)}{16^2}[/tex] = -0.281 N/C (it's negative because it's giving a force towards the negative x - axis)
E_2 = [tex]\frac{(9x10^9)(6x10^-9)}{9^2}[/tex] = 0.667 N/C
so 0.667 - 0.261 = 0.451.
Probably wrong.
Hey Doc Al did you get this problem figured out. As far as i can tell we're all using the same approach...but in the end no success. Any more ideas or approaches to this problem?
did you get the same answer as I did for Part A?
The approach spelled out by cse63146 is correct, but the answers are wrong. Two arithmetic mistakes were made: the calculation for E_1 has an error, as does the final subtraction.
Found the mistake for E_1; it's 0.281 instead of 0.261
so the final subtraction would be 0.667 - 0.281 = 0.386
So in the second case, where q2 is negative (q2 = -6 nC), since it's negative, it would attract the test charge toward the negative x - axis, and thus the electrical field would be negative as well.
So it would be: - 0.667 - 0.281 = - 0.948
