Electric field inside at points on a conductive box
The discussion focuses on calculating the electric field at three points related to a conductive box with a surface charge density of 2.10×10^10 e/m². Using Gauss' Law, the electric field at point a (outside the box) is calculated to be approximately 379.7 N/C, while points b (within the wall) and c (inside the cavity) both yield an electric field of 0 N/C. The confusion arises from the expectation that point c should have a field equal to that of point a, but it is clarified that the electric field inside a conductor is zero when in electrostatic equilibrium.
  • Understanding of Gauss' Law and its application in electrostatics
  • Familiarity with electric field concepts and charge distribution
  • Knowledge of conductive materials and their properties in electrostatics
  • Basic mathematical skills for calculating electric fields and charge
  • Study the implications of Gauss' Law in different geometries, such as spherical and cylindrical conductors
  • Explore the concept of electric fields within conductors and electrostatic shielding
  • Learn about the behavior of electric fields in dielectrics and their differences from conductors
  • Investigate the relationship between surface charge density and electric field strength in conductive materials
Students studying electromagnetism, physics educators, and anyone seeking to deepen their understanding of electric fields in conductive materials.
Caiti
I'm having trouble understanding a concept.
Given a conducting box with point a located outside the box, point b located within the (thick) wall of the box and point c located within the cavity of the box, I have to calculate the electric field at each of these points.
There is excess negative charge on the box and a surface density of 2.10×10^10 e/m^2.
I managed to figure out all parts, but I struggle to understand why this is the case.
Gauss' Law: ∫ E.dA = Q/ε_0
Q = Ne
For point a:
Q = Ne ∴ Q = 1.6*10^(-19)*-2.10*10^(10) = 3.36*10^-9
∫E.dA = Q/ε_0 = (3.36*10^-9)/(8.85*10^-12) ≈ -379.7 N/C
I know the answer is meant to be positive, but I don't understand how. I believed it would be negative as the charge on the box is negative, and so would 'emit' a negative field.
For point b:
0 N/C because it is inside the walls of the box.
For point c:
I initially thought this would be (+ or -) 379.7 N/C to balance out point a, but found the answer to be 0 N/C. I can't find a reason why this would be, other than that the net charge must be negative; however, I don't see why this couldn't contribute a negative charge in order to increase the magnitude of the net negative charge.
For point a, I don't understand exactly what is your question.
For point c think the following. Where are the charges? Are there charges INSIDE the box? The electrical field inside the box is related to the electric charge that is inside the box. Another way to see this is the following. In point b there is no field, so the outside fields become zero in this point, what do you expect to happen as you go to the interior?
Here's a copy of an image explaining where the points are. It has them labelled as 1, 2 and 3, but I used a, b and c respectively.
So with point c, inside, it is determined by point b? I'm sorry, but I don't fully understand
Thank you (=
