Electric field of discrete point charges
Five equal negative point charges are symmetrically arranged around a circle, creating an electric field at the center. Each charge contributes to the electric field, directed toward the center due to their negative nature. The calculations initially presented had errors in considering the contributions from all charges and the correct distances. Ultimately, the symmetry of the arrangement leads to the conclusion that the net electric field at the center is zero. The discussion emphasizes the importance of symmetry in electric field calculations for discrete point charges.
mborn
Five equal negative point charges (-q) are placed symmetrically around a circle of radius R. Calculate the electric field at the center of the circle.
My Answer:
Each one will be place 72 degrees from the other one (360/5),
Each field line is directed toward the center (charges are negative),
I had;
E_x = (kq/R^2)[-cos 72 + cos 36 + cos 36 - cos 72]
= kq/R^2
E_y = (kq/R^2)[- sin 72 - sin 36 + sin 36 - sin 72]
= 0 N/C
My book says that both E_x and E_y are zero, What did I do that was wrong?
mbron
why do you only have 4 charges in your calculations? plus, i don't think you are calculating the distance squared properly, think about it some more
anyways, i would just make a symmetry argument. hey, works for MIT
Remember that the distance between the centre and any point is R. However, the distance in the x and y direction is not R.
DarkEternal,
Thanks! I missed the one on the x-axis. This gives me -kq/R^2 which will cancel the other equal but positive term.
Parth Dave,
x- and y- have nothing to do with the problem as I am asked to find E at the center. Thank you for caring to answer me.
mborn
