Electric Field of two line charges
The discussion revolves around calculating the electric field at a specific point due to two line charges, with particular focus on the geometry involving inclined and right-angle configurations of the wires.
  • The original poster attempts to identify a starting point for the problem, expressing uncertainty about how to approach the calculation of the electric field. Some participants suggest beginning with the general expression for the electric field from line charges and applying the principle of superposition. Others raise questions regarding the configuration of the wires, particularly the implications of having inclined wire segments.
The discussion is ongoing, with participants providing guidance on how to approach the problem. There is a recognition of the need to clarify the geometry of the wire configuration and how it affects the calculations. Some participants have noted the need to adjust integration limits based on the type of wire segments involved.
Participants are navigating the complexities of the problem, including the specific setup of the line charges and the implications of using semi-infinite versus finite wire segments. There is also mention of the need to consider the orientation of the wires in relation to the coordinate system for easier calculations.
badluckmath
Find the Electrical Field on the O point
##dl = dx\sqrt{1+(\frac{dy}{dx})^{2}}##
I'm trying to solve this, but i don't really know how to start this problem. There are two line charges and i must find the E. Field on the center.
Start with the general expression for the electric field due to a semi-infinite finite line of charge. You may have to look it up or derive it. Then use superposition.
kuruman said:
Start with the general expression for the electric field due to a semi-infinite line of charge. You may have to look it up or derive it. Then use superposition.
Yeah, my confusion is what to do about the inclined wire.
What inclined wire? If I interpret your drawing correctly you have two wires forming a right angle and you want the electric field at distance ##h## from the corner on the 45o line between the wires. Find the contribution at that point for one wire, then do the same for the second wire. The second wire should be easy because the magnitude will be the same and you will not have to do any more integrals.
On edit: Oops! I just realized that you have wire segments not semi-infinite wires. That should only change the upper limit of integration. Also, it might be easier to do the field components if you rotated the angle so that one wire segment is horizontal and the other vertical like coordinate axes.
  • · Replies 22 ·
