Electric field strength (should be easy)
The discussion revolves around calculating electric field strength given a uniform electric field and a flat surface area. The electric flux through the surface is provided as 65 N·m²/C, with the area calculated as 0.0001 m². The formula used is φ = E * A, leading to the equation E = 65 N·m²/C / 0.0001 m², resulting in E = 650,000 N/C. A clarification is made regarding the angle between the electric field and the surface normal, emphasizing that it should be zero degrees, not ninety. The participants express appreciation for the reinforcement of concepts, highlighting the importance of accuracy in calculations.
FrogPad
What is the electric field strength in a region where the flux through a: 1.0cm \times 1.0cm flat surface is: 65N\frac{m^2}{C}, if the field is uniform and the surface is at right angles to the field?
[]----> E
Since the field points at a right angle to the surface we have a norm of 1. (cos(90) = 1).
So we have:
<br /> \phi = 65N\frac{m^2}{C}<br />
<br /> A = (1.0cm)^2 = (0.01m)^2 = 0.0001m^2<br />
<br /> E= unknown<br />
Therefore:
<br /> \phi = E*A<br />
<br /> 65N\frac{m^2}{C}=E (0.0001)<br />
<br /> E=\frac{65}{0.0001}\frac{Nm^2}{C}<br />
Thus:
<br /> E=650000N\frac{m^2}{C}<br />
Did I do this math correctly? I just feel like I am doing something wrong here. Thanks
Your answer is correct, but let me just point something out.
The norm is a unit vector that is perpendicular to the surface, so in this case its parallel to the electric field so the angle (theta) between the norm and the E is 0. cos(0) = 1,
cos(90) = 0 ( I think you knew this but just made careless/typographical error )
hehe, so careful with latex... not so careful with plain text.
I just started this physics course, so all the reinforcement (even mistakes) is awesome... thanks for the double check :)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
