Electric Field (velocity of a particle)
The discussion revolves around calculating the acceleration and final velocity of an electron moving between charged parallel plates. The acceleration is determined using the formula a_y = (qE)/m, resulting in a downward acceleration due to the negative charge of the electron. Participants clarify that there is no horizontal component of the electric field affecting the electron's motion. For the second part, kinematic equations are suggested to find the time taken for the electron to travel 2.0 cm horizontally, followed by adding the change in velocity to the initial velocity to determine the final velocity. The conversation emphasizes the importance of understanding kinematic principles in solving the problem.
suspenc3
At some instant in the velocity components of an electron moving between two charged parallel plates are v_x=1.5x10^5m/s and v_y=3.0x10^3m/s. Suppose that the electric field between the plates is given by \vec{E}=(120N/C)j.
a)what is the acceleration of the electron?
b)what will be the velocity of the electron after its x coordinate has changed by 2.0cm?
F=ma
\frac{F}{m}=a_y
a_y= \frac{q\vec{E}}{m}?
Do I just have to sub in the values for part a?
Yes. I think you have everything you need. Now get started!
so a_y = \frac{(1.6x10^{-19}C)((120N/C)j)}{9.1x10^{-31}Kg}
a_y=(2.108x10^13m/s^2)j?
Careful. What sign is the charge on an electron?
righht, negative, so does that mean that it is accelerating downwards?
Don't you believe your equations?
I suppose...is there a horizontal component of the acceleration?
Is there a horizontal component of the field?
thats what I figured, just making sure.
and for part b, would I use :\vec{E} = k Q / r2?
No, now that you have the accelerations just use kinematics. How long does it take the electron to go 2cm horizontally? Change in velocity=acceleration*time, etc, etc.
pardon my stupidness, but I've always been bad at this kinematic stuff.
Once I find the change in velocity what do I do?
This is going to make you really feel dumb, but you asked for it. Add the change in the velocity to the initial velocity to get the final velocity?
hahaha, its just one of those days...
