Electric Fields components help
In a rectangular coordinate system, two positive point charges are positioned symmetrically around the origin. At the origin, the electric field components are E_x = 0 and E_y = 0 due to the equal and opposite contributions from the charges. For the point at x = 0.500 m, the angle is determined to be 0 degrees from the positive x-axis, and E_y is confirmed to be 0. To find E_x, contributions from both charges must be considered, as the initial calculations only accounted for one charge. The discussion emphasizes the importance of symmetry and the need to sum contributions from both charges to accurately determine the electric field.
lilangel50us
In a rectangular coordinate system, a positive point charge q = 9.00 nC is placed at the point x= 0.250 m, y = 0, and an identical point charge is placed at x= -0.250 m, y = 0. Find the x and y components and the magnitude and direction of the electric field at the following points.
(a) Find the x and y components and the magnitude of the electric field at the origin.
Since the two point charges are from equal distances from the origin, I got that as E_x =0, E_y=0, and E_net = 0.
(b) Find the x and y components and the magnitude and direction of the electric field at x= 0.500 m, y=0
I figured out that the angle of this would be 0 degrees from the positive x axis.
I realized I never finished typing out everything.
(a) I found that out conceptually. Since the two charges are positive, their electric fields will repel, and since they are equidistant from the origin, the origin will have no electric field.
(b) I'm not really sure what to do here.
I figure that E_y = 0. To calculate E_x, I think I would have to do the following:
E_x = (k(9.00 nC)/(.25)^2)/9.00nC = E_net
Am I doing it properly?
(a) looks ok by symmetry.
(b) You have to add up the E_x contributions for both charges. The one you wrote is for the charge at x=0.25 What about the one at x=-0.25?
