Electric Fields in Equilateral Triangle
The discussion centers on calculating the electric field at the midpoint of a side of an equilateral triangle with point charges at each corner. The electric fields from the two opposite charges cancel each other out, leaving only the field from the charge at the top of the triangle. The user applied the formula E=KQ/R^2, using R as 0.23√2 based on a 30-60-90 triangle. However, they encountered a discrepancy in their value for R, which they suspect may be an error. The final calculated electric field magnitude is 113,422 N/C.
longcatislong
A point charge q = +2.0 µC is placed at each corner of an equilateral triangle with sides 0.23 m in length.
What is the magnitude of the electric field at the midpoint of any of the three sides of the triangle?
3. I want to know if I did this correctly, or totally screwed it up
At point p, the midpoint between on a side, the electric fields will cancel from the two point charges directly opposite each other. The only electric field will be felt from the point charge that's on the tip of the triangle.
So, I did E=KQ/R^2. I found R=.23Sqrt2, by knowing I have a 30-60-90 triangle if a bisect it.
E=(9e9)(2e-6)/(.23Sqrt3)^2=113422 N/C
I don't get the same value for R, but it might just be me.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
